visual id
Dav
26
riverview, fl
ranger xlt
Engine Type
2.9 V6
, 2.9
2WD / 4WD
2WD
none but it is a convertible
stock
i know the 88 and earlier 2.9's have round bosses where the rockers bolt down, as opposed to the 89 and later having square mounts. but to see this the valve cover must be removed.
is there any way to tell a pre 89 from an 89 or newer by just looking? any marks, numbers or casting changes that can be seen while the motor is in a truck and completely assembled?
this year is the year of suspension restoration and upgrade (96 TIB with the better brakes) and keep it running repairs. next year is the year of the motor rebuild, and maybe the trans. (i'm doing the stuff that in 5 years i will be too old (i'm already kinda old) to do or will not be able to afford on a fixed income. this truck is the last vehicle i ever expect to own)
tomorrow i hope to be looking at an 89 as a potential donor but want to be sure it hasn't been retro fitted with an earlier motor. it's 75 miles away so i only want to make the drive once.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Not sure you can see the casting numbers, 89TM
But newer model head did have less curves in valve covers lower edge
Pictures here: http://therangerstation.com/tech_library/2_9_Page.shtml
So on the drivers side front or the passenger side rear the valve cover should be straight, 1988 and older will be curved
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
A legend to the old man, a hero to the child...
86/87 has a bigger throttle body then 88-92s.
Doesnt help much though if your engine is a 88.
BrutalPanda
5
Ground bolt on the back of the driver side head will be 10mm if it's the newer heads. 8mm for old heads
Sent from my XT1565 using Tapatalk
Staff online
Shran
April Truck of The Month
