2002 2.3 automatic
homegrownranger
Florida
2.3
The clutches in my ranger are tearing themselves apart and it no longer will shift properly after 232,886 miles. I was wondering what other trannies I could put in it so I can get it back on the road. I heard that a 2.5 had the same bell housing I dont care if it is manual or automatic. thanks for the help
press 1 for english
8
Arcadia, Fl
2.3
Clutches in an automatic transmission?
Rose2300
7
ID
Toyota
3.4
does he mean the clutch packs?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Yes, automatics have clutches. Direct clutch, coast clutch, intermediate clutch, etc.
I'm thinking he means that the friction discs are worn out. Not sure how that would be determined short of a full R+I on the trans.
Anyway, stick to your own year for autos. Any 4-cyl manual up to mid-2001 should be fine.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
2001 and older 4 cylinders have a different bolt pattern from the Duratec (2002+) engines. You need a trans from a 2002+ 4 cylinder truck.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Yeah I know, but the truck in his profile is a 92, so I'm confused.
Staff online
Shran
April Truck of The Month
