F150 302 swap? Good place to start?
YungICY
2.3
Hey guys, I've got an 85 ranger prerunner that I have recently turned into my full time project toy. I currently have the 2.3 in it but the motor is shot and I'm getting ready to do a rebuild but on the other hand I could probably swap in a 302 for a comparable price as to building the 2.3 for power. I don't really know anything about doing the 302 swap but im confident that with some research and a big hammer I can do it. my question here is, I just found an 87 f150 302 with a manual trans complete truck for less than just a simple master rebuild would cost me for my 2.3. Would this truck be a good place to get started for this swap or am I better off looking for something different?
YungICY
2.3
Thank you for pointing me in the right direction. Much appreciation. :)
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,833
SW Iowa
Engine Type
V8
5.0
The intake won't fit because it is huge. Probably be best thing going right now is to grab the intake and cam out of an Explorer and switch it over to that style. On top of them being thinned out (and filling up junkyards) they are one of the better performing intakes out there.
The trans in the truck has the shifter pretty forward, the 97+ trans fit better with the shifter farther back like a Ranger transmission. If you are 2wd you will need to watch for the speedo drive on the 97-98's. 4wd won't matter as long as you use a t-case with a port. IIRC with the 97+ stuff you may need to change the gear inside to properly work with the cable drive gear (Look for Twister's build thread, pretty sure he changed it in his 97-98 t-case)
The trans isn't a direct bolt in, you will need to enlarge the holes, the ones on the 97+ trans are 12mm. A sbf uses 1/2" bolts (12.7mm) Easy enough to do into aluminum, just putting it out there.
YungICY
2.3
Thanks 85. As far as fitment issues under the hood the only thing I'm concerned about is the frame rails because I'm going to be cutting off my front clip entirely and doing an engine cage. Now that 87 motor would be an EFI motor correct?
As far as shifter fitment in the cab, I am going to be completely removing the dash and what not to give me more leg room and make more room for a cage. Here's a link with picture references http://www.therangerstation.com/Magazine/Summer06/seanshaw.htm will this give me enough room for the shifter from the 87 f150 or would I still need to find a trans from 97+? I don't mind if its a bit of a reach as long as it fits.
Speedo and all of that stuff I'm also not worried about since this will only be a play truck for offroad use only. At the most it might get registered as a vintage vehicle so that I can legally tow it on a dolly rather than a flatbed here in Utah. If I don't go that route though it will only be registered as a strictly OHV.
Thanks again.
YungICY
2.3
Oh and for the trans not being a direct bolt in, are we just talking about the size of the bolts or does this include the location of them as well? I currently have a crossmember that I built myself in there now that also is the mounting point for my radius arms. I can very easily modify that one to accommodate bigger bolts or I can just build a new one if it needs to be in a new location all together.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,833
SW Iowa
Engine Type
V8
5.0
The hood interferes with the '150 intake, that is what the snag is. If you are not running a hood it wouldn't be an issue but it wouldn't be bad to have something over the engine to keep the weather out at any rate.
Bolts for the bellhousing. Just too small, location is correct. May or may not line up with your crossmember, just depends on how the chips land when you get it together.
YungICY
2.3
One more question off the top of my head before I commit to go and pick this truck up. What were the options for the rear ends in the f150? And what were the lug patterns? Thank you for all your help. You've given me a great start as to what to expect.
Mac
183
C. Wisconsin
2000
199
4.0
Problem is that the '87' F-150 still had a flat tappet cam. Not sure if it would be a roller block or not.
Dave
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,833
SW Iowa
Engine Type
V8
5.0
8.8, 5x5.5. Explorer has the same but with the same 5x4.5 as a Ranger, 95+ has disk brakes.
Dave
That is a good point, I am pretty sure after '86 they were set up for it.
YungICY
2.3
I have one other issue that might kill the deal for me. The f150 is 4x4 and I'll be keeping my truck 2wd. What are my trans options here? Can I make the 4x4 trans 2wd for a decent budget price or would I be better off getting a different 2wd trans all together. This might kill the deal because for the price of the full truck it will marginally be affordable for me but I don't think I'll have the funds to get a new trans or pay for an expensive adapter for the 4x4 one.
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
First, I haven't read the previous responses. I would just run the trans with t-case if the front output isn't a slip yoke. That could be really handy when towing or moving trailers in a tight spot because of the lower gearing option.
Edit; My above suggestion is made without any real knowledge of what's involved, it's just something I've thought of doing myself. It may also work if you use larger tire rather than changing rear end gears, but again I haven't really checked into it.
YungICY
2.3
That is a pretty genius idea, only question there is clearance for the tcase I suppose.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,833
SW Iowa
Engine Type
V8
5.0
Shouldn't be a problem depending on what you have. If not a JY case is usually under $100
Members online
Shran
April Truck of The Month
