Turbo truggy
mavereq
Concrete, WA
Adapter pipe?
The front discharge compressor cover fixes the issue
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
a section of pipe to alter the position of the turbo.
your braver then me... there is no way in hell I would build a rig with a tiny engine that was not ridiculously easy to work on from the room afforded because it was custom built...that engine bay framework has me at a loss....from the pictures...you bust an engine or trans mount and wad up the turbo at w.o.t. its gonna be a bummer..
mavereq
Concrete, WA
To each their own. I’m not going to remote the turbo. If anything, I’d move it back towards the firewall by building a new manifold.
I’m not sure why you think this is hard to work on. What do you do in your engine bay? I can easily get to the intake and exhaust sides; I can change a head gasket in this quicker than a stock ranger, and I can reach the bellhousing bolts from the dog box.
1991fordranger1
117
3.0 Mercedes diesel
I agree man to each their own.
I think it's awesome and I agree it's more logical then a "engineered" vehicle. a miss is as good as a mile!
Sent from my SM-G930W8 using Tapatalk
BlackBII
Ranger Custom
Truck of Month
982
UT
A silicone 90 elbow would work as well wouldn't it? I guess that would mean an additional clamp though.
Loving the progress! Looks great man. :icon_thumby:
mavereq
Concrete, WA
I was planning on using a silicone 90, but I have the outlet right between the manifold and the wastegate. It’s a little too close for my liking.
I get what he’s saying about the risk of a broken motor mount. I’m not worried about the, because the engine can’t shift far enough to the passenger side to run the Turbo into the strut.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
remote? no...didn't mean that.
I meant a short section with a slight tweak to reorient it a bit. not enough pictures to know what you have, just going on the comment you made.
I like to be able to quickly remove the powertrain complete if possible. and the most room I can manage. I assume you will use filler panels of some sort. when its hot and an issue comes up while your thrashing on it...its nice to be able to get my big dumb head in there to investigate....
if the front is wide open it makes that easy. t case or trans leaks when you can remove as an assembly quickly makes keeping things clean and dry a breeze......of course using light weight stuff it don't matter. my setup is 4 years old and don't really leak...but that is not always the case.
not knocking you, to each their own.
mavereq
Concrete, WA
Haven’t had much time to work on the ranger the past ten days. I played around with some paint on the back of the cab. I want to have that painted before I start building the back half. I think it’s going to look good in machinery gray.
mavereq
Concrete, WA
mavereq
Concrete, WA
I’ve been busy working on other rigs lately. Once I finish this scout cage, I’ll get back to the ranger.
wiggle_wagon
1997 5.0 Explor
Blue 0val.
Nice looking Scout 800! Very sweet cage too.
mavereq
Concrete, WA
Thanks. It isn’t mine, but it’s pretty clean. It’s getting an explorer 5.0, ZF5, np205 combo
mavereq
Concrete, WA
Got a little work done on the back half
mavereq
Concrete, WA
Not sure why these pics cam out so big
BlackBII
Ranger Custom
Truck of Month
982
UT
Looking good man!
