Welp, im commented.
jarfly
So I jumped the gun today and bought a 5.0 out of a 91 f150. 48k on it.
so I think I got the basic concept down of the swap but kind of stuck on the trans part. I think i'm going to end up use a 4spd out of a 79. Did't see anything on it in the tech library. Going to use a 4spd, I will have to make a trans x member but what about drive shafts? Will I need custom or what could I do? Allso would my 91 manifolds work?
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
If you're doing a 5.0 swap and have to ask about the driveshafts don't you think you're not ready?
First off, I'm assuming this is a 4wd? You mentioned driveshafts but nothing about a transfercase. What do you want to know about them? Do you want to know if you'll have to extend them?
Also, what was the comment? You said you were commented, so what was the comment and what was it about?
Fant
U may can use stock crossmember. Or the f150 just botch for the f150 trans and cut to legnth if needed. Using the ford 4 speed. U either need internal hyd slave frm racing parts thats like 400 bucks if itl work on it. They use them on t5 setups. Or make a bracket and use pusher or puller external hyd slave as teddeyzee did. Along with others. Look up clutch setups in this forum itl help u with idea of what u need. As for driveshafts. I used 92 explorer reaer drive shaft and 84 f150 front driveshaft. Both was great fit. But im running r2 trans and np208 tcase. Good luck.
Hagan
11
Salem, OR
2.3
I was thinking maybe he meant committed?
stegomon
20
auburn/minot maine
fords and only
have the guys from trick my truck help?
stegomon
20
auburn/minot maine
fords and only
<~~~~ sweet 1901 post!!!
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
I'd be willing to bet the motor has more than 48k on it, and even if it does, its a non ho motor making minimal power, a stock 4.0 has more power than the 91 5.0. You will need to replace the intake, the truck intake won't fit even with a body lift. If 2wd, the M5ODR2 might be a better option for the overdrive. For 4wd, depending on tire size and use, the np205 May be the tcase of choice, although others are usable. Driveshafts depend on engine placement, trans type and tcase selection...
SVT
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
By 4 speed you mean an np435? I'm running one out of an 84, hydraulic, and love the granny low first gear but in return, low mpgs.
As said an m5od2 would be better for the overdrive. Also the np205 is more compact then the np208 but is also a heavy pig and doesn't have a good low range.
Now you can convert the engine to HO, like I did mine, with a HO cam swap but if staying FI, you will need an HO EFI setup.
Sent from my rooted SPH-D710 using Tapatalk 2
jarfly
Sorry idk what happing with the post, may have been my phone or i'm just crappy with spelling and all that.
But yes the motor has 48 on it, Know the truck, buddy had it since new.
I was going to go with a carb depending on what all I get with the motor.
I all ready have the bulldog, Was going slap it in and wheel it, Any thing bets my blowed 3.0 atm.
Again sorry I ain't been able to get good info on stuff I have, have not got items in hand yet.
