stretching the wheel base
truckguy
FORD
whats the easiest way to move the rear axle back? whats the furthest it can go with out going crazy? any help is appreciated. thanks
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
What are your desired results. Not much room on a b2 to stretch
xkotyx
Solid Axle Swap
20
Waynesboro, VA
4.0
do you plan on cutting out behind the wheel well?
The_Dealer
10
Macon, GA
Duh!
wagoneer springs (offset pin), ruffstuff perch kit(mighta been ballistic) with 3 centering holes if u dont want much, fsc leaves(64")or coil set up
i'd say it really depends on how much lift and what size tires u are running. but without cutting the fenders it will be useless. mostly coil'd rear guys would need an inch or two because of the way the control arms pull the axle towards the front of the fenderwell with high lift springs
truckguy
FORD
the reason i ask is because i plan on swapping a ranger cab and bed onto a bII frame, i would like to extend the wheel base so it doesnt look so stubby and i can cut less off the bed.
The_Dealer
10
Macon, GA
Duh!
im gonna do the same thing later on down the road...64" chevy springs, they have an offset pin, try to move them back as far as u can, then get the 3 centering pin hole spring perch for an additional 3" of movement...that should give you around 7" ext over stock rear
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Go to the rbv's under construction area and look at some of the trucks that have done that already.
BONES
Solid Axle Swap
4
Canada Eh!!
gt40 5L
The stock BII/Explorer rear springs are offset center pin too, you could flip them around and get a longer wheelbase.
truckguy
FORD
what do you mean flip them around? and how much would it be moved back?
NMB2
July 2010 OTOTM Winner
OTOTM Winner
Solid Axle Swap
22
Cody, WY
5.0 V8
this is 104" on a B2 with about 18" of frame chopped off the rear.
I run flipped Trailgear leafs on the rear, and right way on the front.
BONES
Solid Axle Swap
4
Canada Eh!!
gt40 5L
Flip them around, as in swap the front bushing eye of the spring to the rear. make sense?
truckguy
FORD
bones that sounds pretty simple lol how much will it move it backwards about?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
The big obstacle is gonna be the fuel tank...
04sd
'90 / '84
4.0 / 4.0
This might be of some interest to you... **bed shortening**
cammeddrz
Solid Axle Swap
23
Ford/chevy
efi 350vortec
why hasn't anyone brought up the fuel-tank location, between the frame rails, and behind the axle........how much room is there before the fuel tank interferes?
Staff online
Shran
April Truck of The Month
