Bronco II I'm going to buy has a problem
Xandor
3
Bloomfield IN
2.9 2.9 2.3
This dude has a BII about 2 hrs from me I'd like to go buy tomorrow. Problem is it only stays running when the key is turned. He messed with it so much he burned up the starter and put a new one on, replaced solenoid, he thought it was tumbler replaced that and it didnt fix it. Any ideas befor I go lay down $600?
I hate the idea of buying a truck without driving it but a 100% rust free BII for $600 does'nt EVER come by up here in indiana. This one is from TN, I was told I can still see the red dirt on the frame lol.
rangertoy
Firefighter
EMT / Paramedic
Solid Axle Swap
ASE Certified Tech
Bay Springs, MS
Engine Type
3.0 V6
3.0
2WD / 4WD
Solid Axle Swap 4x4
6?
could be the ignition switch
Rangered06
2
toledo,ohio
ford
4.0L V6/2.9 V6
if it is just a ignitin issue and everything is up to snuff trailor that bad boy and do a good once over all the ignition wireing maybe it has a short somewhere
gwaii
2010 OTOTY Winner
OTOTM Winner
2010 Truck of The Year
66
haida gwaii
ford
460
$600 for a clean b2,even if you have to replace the motor you are still coming out ahead.
low_five
Kodiak, AK
Ranger
2.9
The redneck in me wants to wire a toggle switch so the coil has voltage bypassing the ignition key. And drive it home with dukes of hazard music playing.
gwaii
2010 OTOTY Winner
OTOTM Winner
66
haida gwaii
ford
460
and this is a problem how?
heptofite
62
Engine Type
2.3 EcoBoost
2WD / 4WD
2WD
did he attach the system power on the wrong side of the solenoid?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
+1:icon_rofl:
Xandor
3
Bloomfield IN
2.9 2.9 2.3
buy it, fix it, drive it. can't go wrong for $600. just my $.02.
Thats what I'm thinkin. Going first thing tomorrow, heck I'd still buy it if the motor was blown.
feellnfroggy
28
Knoxville, TN
4.0L
I agree with all them, Setup a pushbutton start and forget about it. 600 bux is a bangup deal on a b2, You better not be buying the one in dandridge, that one is mine. lol, soon as i get some money.
Tb8983
Forest Grove, OR
Not big enough
Hey I kinda know thefeeling I bought my bronco 2 with no clutch I mean it started and Rand but wouldn't move so couldn't test out 4 wheel driveor nothing talked the guy down from 700 to 450 and call aaa and had it towed home put a clutch in it and really haven't had a problem with it other then a feul system problem that took for ever to figure out and it was a orignal owner with a 116,xxx milies on it so I couldn't complain
stimmie78
Uinta Basin, UT
I bought my first one for $75.. replaced the in tank fuel pump and sold it for $400. It was an 86. The 89 I have now I got for $350 and I've put in an $11 solenoid and working on doing the clutch now. So to me $600 is high =) But if it's clean, do it.
swamprat
3
lexington KY
Engine Type
4.0
2WD / 4WD
What year is it? I got an 89 that I am parting out if you need an ignition
necessaryevil
salem,or.
ford
2.9
my '87 had the same problem when i got it, when i pulled the switch apart, it has two copper pieces with little contact buttons on them, i cleaned the grease, dirt and crud off of them put it back together and worked fine since, just be sure to rebend the tabs that hold it toghther over very well, or it might fall apart on you in the middle of traffic like mine did!!
Members online
Shran
April Truck of The Month
