how to test fuel sending units?
Angie
368
Vancouver area BC Canada
92 & 83 project
Engine Type
V8
4.0L 302
I have an 83 with 2 tanks and I am needing to test the 2 sending units in the tanks to the Hastings gauge I built in the dash. i know it is supposed 73-10 OHMS to move the needle. i can hit the float with a magnet to raise and lower it. whats the proper way to test the whole circuit before i place the cab and box back onto the frame?
thanks
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
You have two options.
1) You can resistance test the whole circuit, or at least as much as you can put together without the body on there, and move the floats.
2) You can resistance test the sending cards now, put everything back together and ground the signal wire to the gauge, see if it pegs out.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Ford used a Yellow wire for sending units for many years, not sure in '83
The wiring for sender is:
5volt pulsed power regulator------Gauge-----(yellow)-------sender----(black or orange)-----Ground
There should be 2 wires at each gas tank, 1983 shouldn't have in-tank electric pump, they used mechanical pump on the engine.
Remove connector at the tank and use OHM meter.
Set OHM meter for 200ohms or 1,000(1k) ohms
Connect OHM meter to each connection at the tank
Should read between 73-10ohms, 73ohms empty, 10ohms full
Move float and watch OHMs change
To test wire to gauge you need to Ground the "yellow" wire.
Turn key on
Select tank you will be testing on the cab switch
Gauge should show below empty with wire unplugged, OHMs are above 73
Now ground the "yellow" wire to frame
Gauge should go to above Full, ground will be 0 OHMs
Test other tank, remember to change the cab switch
Angie
368
92 & 83 project
Engine Type
V8
4.0L 302
Thanks ADSM, The cluster isn't bolted into the dash yet so it is easy to place it beside the main wiring system to test the gauges. wanting to hold an ohm meter at the wiring system before hooking the gauges up to test resistances. then trying the gauge for both tanks.
I am reading that the gauge needs to be proper resistances for the sending units to work proper and being 73 - 10. I have no idea what the gauges are set at that I placed into the cluster. It is a NOS Hastings fuel gauge that I picked up still boxed at a car swap meet.
The back tank is the original, with the 83 sending unit. the front was a nightmare to get, LCM truck tank for the 83, however, the sending unit isn't available anymore for these tanks and I placed in a sending unit from 83-84 bronco 2 as this fit the tank after a bit of tweaking to the float to make it sit properly.
Hope this sheds a bit more light on the "how do I do this"
cheers
(could post a pic if that helps)
Angie
368
92 & 83 project
Engine Type
V8
4.0L 302
Thanks Ron...
we missed each other. and that is the explanation i was needing.
how do I wire in the 5 volt separator? I was able to get a couple to wire in from "ebay" do I place it just before the gauge at the cluster?
RonD
Official TRS AI
8,370
canada
5 volt separator?
Selector switch?
There are 2 kinds, one just does the Fuel gauge, it will usually just have 3 connections.
Wire to fuel gauge goes to the center, then wire from each tank goes either side, so it just selects which tank level gauge displays.
Then you would have a manual tank selector lever next to drivers seat to change fuel flow from tanks.
Second type does the gauge selection and also has connections for 12volt electric flow switch.
12volt OFF is one tank
12volt ON is the other tank
This needs to be wired to a Key on circuit for the 12volts
12v into switch when key is on, then 1 wire from switch to flow valve
Flow valve needs to be grounded to frame or with a ground wire.
Then you need to match gauge selection with flow selection.
So 12v OFF = Front tank on valve and front tank sender
12v ON = rear tank on valve and rear tank sender
This is a universal electric valve: http://www.ebay.com/itm/New-FUEL-TANK-SELECTOR-SWITCHING-VALVE-3-PORT-Main-Aux-gas-FV1T-Duel-DUAL-Switch-/171249453850
You just need one with 3 ports
One to fuel pump on engine
One to each gas tank
Or use manual switch: http://www.amazon.com/Moeller-Fuel-Three-Way-Valve-Brass/dp/B000MTB7QA
Angie
368
92 & 83 project
Engine Type
V8
4.0L 302
5volt drop down. (separator) splitter)
The tank switch is factory and is a slider built in the dash, slide it and that is it. Should still be working fine (as it did when taken apart).
thanks
RonD
Official TRS AI
8,370
canada
Angie
368
92 & 83 project
Engine Type
V8
4.0L 302
RonD
Official TRS AI
8,370
canada
Angie
368
92 & 83 project
Engine Type
V8
4.0L 302
Ok, now I see where I am getting mixed up. I have rebuilt the whole gauge system with after market sets and bypassed that pulse thing, (not knowing what it is). I was told i needed 5Volts to feed the sending unit/fuel gauge and picked up that converter.
here is a link to the picture. Post #21
http://www.therangerstation.com/forums/showthread.php?t=156327&page=3
Now i need to rewire in that part.
thanks
RonD
Official TRS AI
8,370
canada
Yes, me too, was thinking Ford system, stock.
Staff online
Members online
Shran
April Truck of The Month
