Axle shaft rubs
Missed leg day
Passenger side axle shaft is rubbing on the driver side drop bracket or front bracket 6 inch old skyjacker lift kit everything is tight it sits level anyone had this happen before?
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Have you checked the radius arm bushings at the frame. Approx. under passenger seat.
Missed leg day
Yeah I did they don't look that bad lol but nothing to make it move that far forward I hope, I will post pictures a little later thing will be the death of me.:annoyed:
alwaysFlOoReD
Forum Staff Member
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Just to be clear;
Your passenger side axle BEAM is hitting the drivers beam drop bracket [mount]? [drivers beam mount being on passenger side]
Missed leg day
Yeah you got it
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Sounds like something is bent or out of position.
Pics would help for sure (pics of where it's hitting, the d-side beam bracket, and of the radius arms, bushings and mounts).
lvwill
143
Las Vegas Nv.
ford
Engine Type
2.3 EcoBoost
2.3 Ecoboost
2WD / 4WD
2WD
I saw 1 picture and I can tell you for sure that the bracket in question is severely pushed back.. it should be bolted and tight to the cross member.
Missed leg day
Ok is that the first pitcure? Bec its all ran down tight!
alwaysFlOoReD
Forum Staff Member
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
I'm sorry, I will not sign in to anywhere in order to see someone else pics. I don't know how you can make google show your pics. You can load them to an alternative pic hosting site OR you can put them into your "pictures and albums" located in your TRS control panel.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Missed leg day
I tried it didn't take the pictures
Missed leg day
Don't worry about it thanks anyways!
Members online
Shran
April Truck of The Month
