Yukon Dana 35 External C Clip Eliminator
JOSEPH169
12
Marysville, Wa
2.9
So I got a Yukon TTB Cclip eliminator kit and it's got two springs the go inside the slip yoke on the front axle. The kit comes with two different springs. Just curious on which one to use since one is longer and alot stiffer the the shorter one that's softer. Has anyone put this spring on. It's the same kit in the parts store on here.
lvwill
143
Las Vegas Nv.
ford
Engine Type
2.3 EcoBoost
2.3 Ecoboost
2WD / 4WD
2WD
I use it in my ranger. Use the small spring the big one is for a Dana 44.
JOSEPH169
12
Marysville, Wa
2.9
Thanks, I thought so since the bigger spring seems way to stiff. Thanks for the help.
lvwill
143
Las Vegas Nv.
ford
Engine Type
2.3 EcoBoost
2.3 Ecoboost
2WD / 4WD
2WD
Glad I could help. I thought the kit was for the Dana 28 and 35 when I got it and tried to fight the big spring in there. But after a few beers figured it out lol. This was actually at the end of a very long day of gears and ball joints just trying to get the truck back on the floor so I could close the garage.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
You say "External C Clip Eliminator" (circlip eliminator I assume) in the thread title, but then you reference putting the spring INSIDE the yoke, so I'm a little confused...
The D35 and D44 TTBs have the same slip-yoke, so whatever spring didn't fit the D35's yoke, won't fit a D44 either.
The D28 is of course smaller, the D50 (depending where it goes) could be again the same thing as the D35/D44, or it could be bigger.
Got pics of this kit?
lvwill
143
Las Vegas Nv.
ford
Engine Type
2.3 EcoBoost
2.3 Ecoboost
2WD / 4WD
2WD
The 2 springs that come in the kit are the same diameter. 1 is just a bit longer and to stiff.
Can't compress it enough to get the spindle back on the knuckle. I have a feeling that this kit covers all ttb axles.
If I were to do it again I would save my money and just get the weed whacker spring for a couple bucks.
Of course I found a tech article about that after I was finally finished. Lol
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
I used the weedwhacker spring. picture HERE if you need it.
Staff online
Shran
April Truck of The Month
