JackBoehner79
- May 23, 2016
- Reaction score
- 0
- Make / Model
- ford
- Automatic
Hello, I have a 87 ranger 2.9 I recently got from a friend.
Big head ache so far and lots of time and money invested as well.
1. failed smog twice now and both 15/25mph are GP.
A. 1st smog failed at 15mph/gp with hc max 150, mine 440
B. 2nd smog failed @ 15mph 1160, and 25mph 249 was 43 passable.
C. failed evap, along with fuel cap.
2. After 1st fail: I had both Cats replaced, new o2 sensor, new egr valve, new fuel cap, Iriduim plugs, wires, cap, rotor, fresh oil change, new fuel lines from tank to first filter.
3. After Cats put on and roughly 100 miles in truck started losing power when warm( before egr valve was put on), so I replaced egr thinking it was getting stuck open. fixed the problem for a couple days.
After speaking with previous owner, made me think it was the fuel pump and assembly within the tank, being they replaced it with a used 1 of out a wrecking yard from another car altogether. I order new the new 1, installed, but waiting on the second(on rail) to come in along with the filter.
Saturday, I was researching the forums and reading possibly the TPS, so i pulled mine, looked alittle old but decided to get another, but once in the engine compartment i started truck and could hear vacuum leak. Found that is was line leading to the Auto trans and the Modular was faulty as well. So trip to parts store i get TPS, modular and new vacuum line and ran all new line. started and no more trans fluid in line and engine does not have anymore shaking like before.
4. I need to get cats back on( pending trip to get new gaskets).
So question is If once back on and other new pump/filter/lines are on and the truck is still dying and bogging down, what would be the problems now?
Only thing I can possibly think of is new computer, map sensor? I dont know what that sensor is that connects to the egr valve?
there is vacuum on the new egr valve which tells me the solenoid on the passenger fender is working proeperly?
Sorry for such a long post, just trying to detail all what is going on and what has been done. I am sure I am leaving some detail out, and which I am sorry.
