greaseyfingers
- Nov 4, 2007
- Reaction score
- 1
- Age
- 52
- Location
- Crookston, Mn.
- Make / Model
- Ford
if you've ever had to replace your 2.9's ignition module... what kind of abnormal engine symptoms were you experiencing with your ranger...
what functions does the 2.9's ignition module, exactly, control... does the ignition module control the engine's timing advance, the fuel injector's spray bandwith, and the spark plug's ignition firing...
how did you determine your 2.9's ignition module needed to be replaced... did your ranger's engine run fine, sometimes, and erratic at other times... before, discovering your ignition module was the problem...
