1986 Bronco II NOS Tachometer
The Slider
Castroville, Texas
1972
I just got my NOS replacement Tachometer, when I got it the needle was pointing at 6 o'clock. I installed the tachometer and started the truck and had to physically adjust the needle to ZERO when off. works GREAT! when when I turn off the Bronco the needle slowly floats down to ZERO... My old Tachometer just DROPPED to Zero like a rock when I turned off the Bronco.. Is that a sign of a bad Tachometer?
Thanks!
Chaz
Spott
TRS Banner 2012-2015
21
SE Idaho
Engine Type
2WD / 4WD
That doesn't sound right to me. Every needle-gauge in a vehicle (or most anywhere else for that matter), is a milliammeter at the heart.
And they must move very freely and quickly in order to work with any accuracy.
So either you have a gummy meter (which isn't a good thing, obviously) or you've got something strange happening in your tach circuit, that sounds like it wasn't there before.
With some electronics info and a small set of parts you can measure and test your meter, but it's too involved a process for me to type out on my phone. If you have the desire and parts, you can probably find basic instructions with a Google search.
Let us know if you're interested in chasing this issue down.
The Slider
Castroville, Texas
1972
This tachometer I got is a new NOS stock ford tachometer for the Bronco ii. I am going to call the place I got it from and have them send me another one and I will send this one back. I'm sure it was just a bad one. When I turn off the key the needle should drop like a rock to zero. Not float slowly down.
UPDATE! In case anyone cares... They are sending me another one to replace this one. they had another in stock.....
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,847
SW Iowa
Engine Type
V8
5.0
You don't mention it so it probably is a non issue but if you have overlays on the gauges and they are not centered correctly they can drag on the shaft.
The Slider
Castroville, Texas
1972
No overlays.. I like to keep is as original as possible.. :)
Staff online
Members online
Shran
April Truck of The Month
