kpgubert
- Oct 20, 2012
- Reaction score
- 0
- Make / Model
- Ford
First, I would like to say I know these are no rocket ships. My Dad used to have a '98 3.0L 2WD and my last truck was a '94 3.0L 2WD which actually had more miles on it than this one. Both of those trucks had substantially more power than this thing does.
Here is what I'm working with:
I've had it since 2006 and 144k miles. It now has 292k miles on the clock. I realize the slightly bigger tires may slow it down a little, but it is ridiculous! I mean, it can't even maintain 65 MPH up a grade WITHOUT a headwind. Trying to drive on an expressway with a headwind is miserable.
I realize the engine has a fair number of miles on it, but it hardly uses any oil (less than a quart every 5k miles). I have already done the regular tune-up stuff (plugs, wires, fuel filter, cleaned MAF sensor, checked for codes and found none), but where else can I look for where I'd be losing power? Oxygen sensor codes did not show up, but should I replace the oxygen sensors anyway, or is that throwing money away? Yesterday I was thinking that maybe the fuel pressure is down. Should I check this out?
Of course I know that ignition supposedly isn't adjustable on these engines, but when I had my '94 truck with upper-200k mile range it seemed to have a similar loss of power. I checked the base timing on that truck, and it was ~2-degrees AFTER TDC. Once I adjusted it to 10-degrees BTDC it made power like a new truck. Is there some failure of the cam sensors on newer 3.0s that would cause a loss of power?
I'm sorry for the long-winded post, I'm just trying to provide as much information as I can and hopefully get some help. I'm new here, but not to forums in general. In my "spare time" I race my Mustang in SCCA's Solo II competition. I'm very familiar with working on cars in general, but this has me stumped.
Thanks a ton!
- 1998 Ranger, extended cab 2-door
- 3.0L engine
- Manual transmission
- 3.73 axles
- 245/45-16 tires (original was 235/75-15)
Thanks a ton!
