Just a few questions here...
ClodSlayer
Fremont, MI
4cyl. 2.3 liter
I have a old, rusty '87 ford ranger 4x4 that I am currently fixing up with my dad :icon_welder: and I have two questions... First, are there any alternatives to the bed bolts? They are rusted right out and they are like $15 apiece off lmc truck and that is just the bolt then there is the clips which are $10.... So is there any place to get them cheaper or anything I could use instead? Also... I was looking at one of those K&N filters and was wondering first of all weather it would really make any noticeable difference to the little 2.3 litter 4 cylinder engine that is in there. And if it does, I was wondering if it would be possible to just build the connecting pipe myself and buy just the filter. I mean it's like $150 for that piece of metal tubing and it seems kind of steep.....
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Leave your intake system alone. The K&N system will draw hot air from inside the engine bay and cost you power.
The factory pipe comes out behind the grille and gets cold air.
fix_or_repair_daily
3
SW PA
Ford,Chevy,Satu
2.3, 5.7, 1.9
Just go to the hardware store and match up bolts that are long enough and are roughly the same diameter(probably 1/2"), and get washers and nuts to match. That's what I did. I had to cut the heads off the original bolts because they were badly rusted, and I didn't have access to torches. Only difference is you will have to have another person go underneath and hold the nut still while you tighten the bolt.
Josh
racsan
4,442
central ohio
ford/escape
Engine Type
2.5 (4 Cylinder)
2.5/151 I-4
2WD / 4WD
2WD
the grey-t escape
the l.f. bed bolt will not be accessable from the bottom because of the fuel tank being in the way (unless you drop the tank, which i wouldnt do) you might be able to find a blind fasnter similar to what was there originally for that spot. and considering the age of that truck and the fact you have rusty bed bolts, be sure to look at your brackets that mount the rear leaf springs to the frame. they probly should be changed if they havent already been. thats also a much easier job to do with the bed off.
ClodSlayer
Fremont, MI
4cyl. 2.3 liter
All right! So I guess I'll stick with stock air filter then....
I already have the bed off(im trying to get as much rust off as possoble then get some primer and rust gaurd on it) and the brackets are ready and waiting!
I have another question for you guys... What is the one best thing I could do to boost engine power output?
snoranger
Professional money waster
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
I didn't ask for your life story, just answer the question!
ClodSlayer
Fremont, MI
4cyl. 2.3 liter
Huh.. I was more thinking along the lines of to the engine i already got... But Two more questions, this time regarding the picture above... How much would that cost and how much modification to the engine mountings is required to make that fit?
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Sno has the right idea, but he overshot by about a liter.
4.0 makes better power at the bottom and is equal up to the point where it's revving so high that nobody cares anymore.
ClodSlayer
Fremont, MI
4cyl. 2.3 liter
Oh, and Adsm- the factory intake was non-existent when I bought the truck of some guy so I was thinking that I'd I had to replace it, I mind as well make it better, but I now see your point... Maybe a snorkel rig?
And the questions still stand even for the 4 litter...what's the cost and modification required?
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Either way you will need engine mounts, engine, trans, wiring, computer, etc. It's not easy. A 4.0 will fit better.
jhammel85
Guest
Josh
I just did this with my body lift because my J-Nuts were bad on the bed.
ClodSlayer
Fremont, MI
4cyl. 2.3 liter
ok... then what is the biggest engine that will drop in? I'll even maybe go for a v6... I just don't want a line of cars waiting behind me as i slowly get up to highway speed....
gribly
28
Maine
Honda
K20A3
Remember - the factory system sucks in water easy, and you really do get more power cutting all that crap out on a v6 truck. I've done it on a '90 2.9 and a '91 4.0. Doubt it will do anything for the 2.3 except make it louder, though.
ClodSlayer
Fremont, MI
4cyl. 2.3 liter
...so there is no possible way( or nothing thats worth the cost) to increse the power of engine I already have?
snoranger
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
I'm sure there are ways to increase the power of the 4 cyl. but $ for $, the best way to get more power is the 4.0l swap. It really boils down to:
How much more power do you want?
How much money do you have to spend?
Staff online
Members online
Shran
April Truck of The Month
