Killed my ranger last night (Modified V-8/Supercharged) Any input?
dasfinc
October 2011 STOTM Winner
MTOTM Winner
RBV's on Boost
12
Warrenville IL
5.0
I suspect/hope/Pray its a coil after triple checking all my relays/fuses/wiring/etc.
Ignition coil failures are not super uncommon on fords I know, and I kinda suspect that may be what I experienced the other day...
My truck has a No-Start condition at the moment after Friday night (from my build thread):
"Cruised around on new tune for 15 min, no problems. Pulled from 20mph onto 355, had a pop from the exhaust on the shift to 3rd, pulled to 100 in 3rd, no problems. Did it from a standstill and it popped twice on the 2/3 shift and broke up. I let off, idle was loping doing 40mph, no smoke or fluid dumped. Pulled over immediately and stalled out.
Truck turns over smooth, but doesnt start. So I fear I chunked something internally or it's something easy like a dead ECU or pump... (I've killed one ECU already...)"
The truck has shifted with a bit of a 'pop' randomly in the past, and my truck has been especially bad at reliably shifting at the correct points (sometimes would shift at 5500, sometimes 5200, sometimes 5800).
I checked the ECU and all my fuses/relays and everything checks out. My pump primes and is running etc, I can smell a whiff of fuel after cranking it for a while so it seems like its getting fuel but not starting.
I have NOT pulled a sparkplug out and tried cranking it to see if there is a spark, but I have pulled off my coils and tested them both.
Primary resistance on both is 1.0, secondary is 13.6-13.7K
I see a brand new OEM coil is supposed to be .3-.9 on the primary, 11.5-17.5K on the secondary.
I've replaced coils in the past that passed spec before as well, but I'd rather not spend $120-130 in MSD coils unless I'm fairly confident the ones I have are dead, or need to be upgraded anyways....
is being 1.0 too 'high', or high enough to cause a no-start on the primary side? I'd read that a bad/failing coil could have caused my weird shifting habits as well.
The coils probably have nearly 200K miles on them to boot honestly....
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Do the spark test, if it fails, do a spark circuit test. Basically put a test light where the coil should be. If it flashes, get a coil, if it doesn't, get a computer.
hoosier1104
I'm Awesome!
MTOTM Winner
TRS Banner 2012-2015
104
Camby, IN
302 based goodness
Work hard and play harder
If you decide to part out for some odd reason, I call dibs on your s/c. jk. Hopefully everything checks out for you.
dasfinc
MTOTM Winner
RBV's on Boost
12
Warrenville IL
5.0
If you really want to call Dibs, PM me an offer... Its not exactly a cheap or common item :yahoo:.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
dasfinc
MTOTM Winner
RBV's on Boost
12
Warrenville IL
5.0
Coils look to be bad after a few tests... Ordered MSD Performance coil packs, Fingers crossed guys!
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
rotor turning smooth?
pull the dizzy?
dasfinc
MTOTM Winner
RBV's on Boost
12
Warrenville IL
5.0
dasfinc
MTOTM Winner
RBV's on Boost
12
Warrenville IL
5.0
New coils, still no spark, anyone familiar with any other common no-spark conditions for V-8 explorers? I swapped the ECM's with a known good one and there was no difference, and I checked the Fuses and Relays (I'll have to check them again I suppose)
I also now have a puddle of transmission fluid under my truck out of the blue..... but I REALLY think that's completely unrelated unless some how my neutral saftey switch is fried?
If that gets fried what does the ECU Disable (I thought it was fuel not spark) and where is it located on the transmission? (4R70W)
I almost think a wire somewhere has melted/shorted in the harness? I have a new harness to switch to anyways, Guess I might as well now....
Cadger
Georgetown, ON
ford
4.0L
check your crank sensor, no signal=no spark.
dasfinc
MTOTM Winner
RBV's on Boost
12
Warrenville IL
5.0
Ima go buy a scanner tonight finally... might as well.
AgPete139
09/2014 OTOTM Winner
OTOTM Winner
Solid Axle Swap
61
Houston, TX
Engine Type
4.0L OHV
2WD / 4WD
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Hm. Got me. Keep us updated...
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
Whats a rotor :icon_rofl:
I'm one of only a handful of people running a OBD2 setup :icon_thumby:
one of the few on this board?
same thing. is the cps working ?? valves moving cam spinning?
chains break, gear bolts shear etc....
bilzy7
32
Lynn, MA
4.0 SOHC
But nuts don't bust.
shane96ranger
221
Utah
Ford F150-Stang
Engine Type
V8
4.6 Triton / 5.0
Check your cam synchronizer. Just wondering... the cam you put in it - is it a roller cam? I don't recall what the gear on the cam synchronizer. Hopefully steel.
Staff online
Shran
April Truck of The Month
