Odometer not working but speedometer does
Lybmeanit
I replaced the entire cluster and the odometer still doesn't work any suggestions?
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Welcome to TRS :)
Electronic speedometer/odometer setup is the same as older cable driven, both share the same signal, spinning cable or electronic pulse.
So problem was/is in the cluster itself if speedometer works and odometer doesn't, or visa versa.
The plastic worm gear that drives the odometer was a know issue with that vintage instrument cluster.
Article here on checking/replacing it: http://www.therangerstation.com/Magazine/Fall2008/odometer_worm_gear.htm
Lybmeanit
Thanks it was the worm gear
The worm gear was broken on the one and the little motor looking thing was bad on the other . I used good gear and motor and it's working.
RonD
Official TRS AI
8,370
canada
Good work :icon_thumby:
Thanks for posting the update and the fix
Staff online
Shran
April Truck of The Month
