Rear Antilock light on, no tailights or turn signals.
TGM
I have an 89 Bronco II. When I turn it over, the rear antilock light stays dimly lit (Like it's only part way engaged) There's nothing wrong with my brakes, and I used to be able to flick the ignition again really quickly and it would go out. Now it takes a couple minutes to get it off, if it even will. When the light is on, I have no brake lights or turn signal lights. What could be causing this? A worn ignition lock cylinder? Wiring issue? It's the most annoying thing in the world and I need to get it fixed fast.
wildbill23c
TRS Banner 2012-2015
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
Sounds like a short somewhere.
The rear ABS light in my 88 B2 is on all the time, not worth the hassle of tracing the problem brakes work just fine without that 1/2 ass ABS crap.
TGM
Yes, but while it is on my brake lights and turn signals don't work.
fangotango306
8
sc michigan
ford
None yet
could be a ground issue. if you have a trailer harness start looking there.
TGM
It's also been having problems with stalling out. I'm thinking it's an ignition switch.
Staff online
Members online
Shran
April Truck of The Month
