Steel Braided Brake Line.
M3xpress
Birmingham, AL
2.8L
I need to replace a steel braided brake line on the driver's front. I've seen where there are a handful of places that sell the sets, but I was wondering if anyone knows where I can get just one or get one made?
I was also wondering if anyone knew the specs of the stock line. All I know about the steel line that I have is that it's smaller in diameter than stock and four inches longer than stock, that's all James Duff could tell me.
I was hoping to replace this without buying a whole set.
gribly
28
Maine
Honda
K20A3
You might be better off with normal brake line, but extended enough for your lift. Steel braided line can trap grit in between the steel and the actual line, and it can eventually grind a hole in the line. I've seen it happen on a lowered honda before. You should be able to just go to your local parts dealer or a anywhere that sells stuff like that and get a line in the correct length.
