M5OD question...
chewy012
Colorado Springs, CO
4.0 OHV
I have a 2wd 1992 4.0 with a M5OD.
The confuser always pulls a code for "not in park/neutral".
Do all generations have a neutral position switch/sensor?
I just had the tranny out an did not see an unpluged connectors... When I pull't the tranny, it was just clutch line, speedo, and reverse lights...
Sent from my XT1254 using Tapatalk
The early ones had a plug opposite the reverse light switch that was for a neutral position sensor. I think it was dropped in 93.
chewy012
4.0 OHV
Hmmm, I looked at that spot where the diagrams show it, but it just looks like a blank.
It kind of sounds like maybe that truck originally had an auto-tragic trans and nobody changed the computer.
What is the transmission code in the VIN?
A4LD is a T.
M5OD is an M.
jimmyfloyd
A4LD is a T.
M5OD is an M.
You can tell the Transmission from the VIN?
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
@ adsm08
Which number position indicates transmission? I goggled a bunch of sites including ford and none indicated the vin contained transmission info.
85_Ranger4x4
17,910
SW Iowa
Door tag then.
I am used to getting this info from decoders, not doing it myself.
chewy012
4.0 OHV
Door tag then.
So the VIN on the door has a T in it, but is marked M under trans...
Hmmm
85_Ranger4x4
17,910
SW Iowa
Hmmm
There are several positions for a T in the VIN but none of them refer to the trans.
