universal timing cover with crank position sensor on carburated engine
l0sts0ul
Edmonton, AB, Canada
3.0L
ok, sounds dumb, but hear me out.
got a universal timing cover for my 79 302 mexican. now, I go to see how to setup timing, and find holes for a crank position sensor, but I can't install a timing pointer.
HOWEVER, my balancer that came with my kit has 3 sets of timing marks on it, can I just build a custom pointer, and use the other marks? if so, how to I know where my base timing is set to zero so I can make sure my pointer marks line up 0, to where its supposed to be. if the 1st cylinder is on TDC at the beginning of the intake stroke should the timing mark be at 0? depending or no matter what set of marks I use?
by the way its a performance products harmonic balancer
http://www.professional-products.com/6-4-Early-Small-Block-Ford-28-4-oz-in-Harmonic-Damper-p418.html
thank you
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
TDC(top dead center) is when the piston is at the top of the cylinder, it has nothing to do with the valve positions or the "stroke" it may be on.
For #1 TDC remove #1 spark plug and rotate crank until piston is at the top(TDC)
If possible add your timing pointer to line up with existing mark/line for "0" on balancer, if not possible then make your own mark on balancer.
Because we are dealing with a 4-stroke engine, the crank needs to turn 2 full revolutions, 2 up and 2 down strokes, for one complete cycle.
This is why the Cam timing gear is twice the size of the crank gear, the cam only rotates once during the complete 4-stroke cycle.
The Cam is what sets the "strokes"
So #1 TDC comes around twice, at the start of the power stroke and the start of the intake stroke.
But as far as the TDC mark is concerned you just need #1 TDC marked.
The balancer is 360deg regardless of size, so if the TDC line is at 12:00, then 3:00 would be the 90deg mark
1/2 the distance between those marks would be 45deg, 1/2 again would be 22.5deg, 1/2 again 11.25deg, 1/2 again 5.5deg(close enough, lol)
So if you need exact degrees you can use that method for BTDC
l0sts0ul
3.0L
Ok. So you're saying put cylinder 1 at TDC and I can set marks and pointers however I want at that point?
RonD
Official TRS AI
8,370
canada
Yes, what ever is the easiest to do and, of course, to point a timing light at :)
Members online
Shran
April Truck of The Month
