deranged88
- Nov 30, 2011
- Reaction score
- 0
- Make / Model
- Ford
I've been a member for some time now. Finally had something I'm in desperate need of help with.
I am working on a 1995 ranger 4.0 5 speed electronic 4x4.
So I picked up this truck a few days ago knowing it needed a lil love. Well Im balls deep in this thing now.
The starter was hooked up to a push button. Fuel pump is direct wired from the ignition under the column. Truck was wrecked at some point in its life and drivers bag is blown.
I've already figured out the push button ignition and deleted it. No idea why they had it since I hooked the solenoid back to the ignition and it worked just fine.
I'm stumped on the fuel pump. I have power at relay. I have 12 volts at inertia switch key on then drops to 6 volts. I haven't figured out which wire to test coming out of inertia switch to test for power. Hooking up my scan tool I'm getting a fuel system 1 cl fault amon gst other trouble codes that im massaging out.
I've attached 3 pictures. One of drivers kick panel floor harness where i found a cut light blue with white stripe wire. Another that had been cut but wired back together.
https://imageshack.us/i/poafrdJzj
Other pictures are of passenger kick panel where multiple wires have been cut and retied in. Some not to the same color. And 6 or 8 wires that are just cut.
https://imageshack.us/i/po3SVjCkj
https://imageshack.us/i/pnFlkm15j
The truck is missing the key fob and I only have a remade key to the igntion. I do get the 25 beeps once igntion is turned on. Drivers air bag had been deployed at some point. Would like to know how to fix that as well.
Can I just replace air bag or is there a sensor in the front fascia somewhere so I don't pop a new bag.
Also. Does anyone have any of the little warning light bulbs with sockets? I have a few that are missing. My guess is the instrument cluster lights up like a Christmas tree so previous owner removed the bulbs.
I'm sorry so many issues in one thread, but I didn't want to make multiple threads.
PHP:
