96 5.0 42 pin conn. To 94 4.0 ranger harness
ATX
11/2014 MTOTM Winner
MTOTM Winner
2
Austin tx
5.0
Built not bought
Ok guys well I'm getting the wiring straighten out right now . So when I pulled the wiring from the expo I made sure to cut as much extra as I could which is enough to reach over to the stock ecu location on the driver side bulkhead . Svt was awesome enough to send me the 42 pin out for the expo harness but I need to find the info to connect it to my ranger harness for power and such and at what connectors to splice into . I labeled every wire on the 42 pin harness with tape so I don't have to keep looking at the chart Svt gave . I know there's like 4 harness connectors that ran to the 4.0 motor that I disconnected . I've been looking on alldata pro at work and haven't came across the diagram yet . A least if someone know what those connector numbers are I can look that up . Thanks guys
ATX
MTOTM Winner
2
Austin tx
5.0
Built not bought
Here's a pic of the harness I disconnected from the engine that's attached to the body still
ATX
MTOTM Winner
2
Austin tx
5.0
Built not bought
Well found the info at work on what number the connectors are hope this info help any else in my boat .
ATX
MTOTM Winner
2
Austin tx
5.0
Built not bought
And this is a chart I found after while looking for my expo 42 pin connector . Svt has a even better copy of a spread sheet that he sent me with other ranger chassis newer then mine which would help some . His cool and pretty sure he'd sent that if asked
Staff online
Shran
April Truck of The Month
