Looking for advice on my engine swap. Will current 5spd match up with explorer 5.0 sw
Bthur321
I've got a 2000 Ford Ranger XLT with a blown head gasket so I am swapping the engine with a 2001 Explorer 5.0 l. The current transmission is manual and I am wondering if I will come into problems. Also, what's a good price if I were to have the swap done? I'm no mechanic...
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
646
Central Indiana
3.0
You should try searching. This topic comes up all the time. The short answer is no your stock trans won't work.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The long answer is that this topic has come up a LOT recently. When possible everything should be upgraded as a system, so engine and trans together, and when it is not possible, assuming everything else does line up, the engine should be the LAST thing upgraded because it is what does the breaking of other things when parts are mismatched in strength.
Frankly, and I wish this particular comment by itself could be stickied everywhere, when swapping in a 5.0, not only will it not work with your stock transmission, there should be no expectation, or even hope, that it would so please don't ask.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,833
SW Iowa
Engine Type
V8
5.0
Well in Fullsize-Ford-Truck-Land a lot of engines do share transmissions. 300/302/351...
Way too simple for Compact-Ford-Truck-Land :icon_twisted:
OP, if you want a manual trans shop for a 97-03 4.2 F-150 with a 5 speed. And if you are not a mechanic now, you will be well on your way by time it is over.
Members online
Shran
April Truck of The Month
