2.9 with edis?
bronco_lou
Columbia, SC
94 explorer 4.0
Does anyone know of someone that has changed a 2.9 to edis? I am in the process of putting a complete wiring harness from a 94 explorer in my 88 bronco ii, I plan on someday putting in a 4.0 but for now I am going to run my 2.9. I need to look at the computer pin outs and see if there is a easy way to hook up the 2.9...trying to keep the explorer harness intact so when the 4.0 goes in it will be plug and play.
Thanks,
Louis
bronco_lou
Columbia, SC
94 explorer 4.0
Also I need one more thing....does anyone have or know where I can get the computer plug pinout for the 88 bronco II with Auto trans?
Thanks,
Louis
Ranger44
Ford Technician
23
Illinois
FORD
4.0 OHV
I'm sure the 3L and 2.9L TFI systems are pretty close if not the same.
I would maybe look for a 4L Crank pulley with the teeth and a CPS.
A EDIS6 module, and make your own wiring harness.
It's very doable, and I am in the "slow" process of converting mine. I'm just lazy and unmotivated.......lol
bronco_lou
Columbia, SC
94 explorer 4.0
What all did the 3.0 come in?
Louis
adsm08
Senior Master Grease Monkey
Ford Technician
3,614
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Louis
Taurus and Aerostar are the vehicles that that will be your best bet.
I know the TFI systems are close enough that you can pull a 3.0 TFI and use it on a 2.9
I do have one question, mostly out of curiosity. Why are you trying to run a 2.9 with a 4.0 harness? Why not just wait to do the wire work when you put the 4.0 in?
Although an EDIS 2.9 would be awesome, I'm not sure the PCM is going to support it.
bronco_lou
Columbia, SC
94 explorer 4.0
Well it all started when I thought it would be cool to have an updated dash, so I pulled a dash from a 93 explorer, and after some cussing and head scratching it was done...so I thought, I later found out that the bronco II and the explorer fuel sending units use different ohms range (fuel gauge didn’t work) and I think I cut a wrong wire cause my overdrive quit working. I went and pulled a sending unit from a 94 explorer and was happy to see that it dropped right in my tank. I pulled out the old bronco fuel system and ran the explorer fuel lines from the tank to the engine. Then I pulled the entire wiring harness from a 94 explorer 4x4 and started the transformation on the bronco. All I have done so far is modify my tail lights to accept the newer type socket, and drill two holes in the body for the wiring harness to pass through for the tail lights. I modified the doors and the post the door hinges to so the wiring harness can follow the same path it did in the explorer. I am all done now and almost to the point putting the dash back in and see if my monster will come alive. I just have to come up with a plan the get the engine running for now. I plan to make it 4x4 and put a 4.0 in and when that happens it will be all plug and play.
Thanks,
Louis
adsm08
Ford Technician
3,614
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Well, certainly an interesting idea. I somehow doubt that it will be fully plug and play for your 4.0 though, for one reason:
On the 2.9 the TFI module handles the firing of the coil. The PCM handles that function on the 4.0. The 2.9 computer simply isn't programmed to handle that function, and so to run it with the 2.9 computer you will have to find a way of running the TFI module in there somewhere.
You'd almost have been better to find an 89 or 90 B2. It would have worked plug and play, and the 4.0 engine harness would have plugged right into the dash section.
bronco_lou
Columbia, SC
94 explorer 4.0
So would an engine harness from a 89 or 90 B2 plug into the 94 explorer harness?
Louis
holyford86
Some guy with a problem
RBV's on Boost
GMRS Radio License
648
Plattsburgh, NY
many
4.0
2WD / 4WD
33x12.50R15
no, the wiring harness would not interchange. The EDIS module and the TFI use the same pins at the EEC so you could just splice in the wiring for the TFI and figure out a way to power your coil If you wanted to save yourself a step in converting the explorer harness to the 2.9 use a 1990 cali emissions BII computer, that way you can just install a MAF and splice in the TFI and you would be ready to go
bronco_lou
Columbia, SC
94 explorer 4.0
Well I have decided to go ahead and get a 4.0 to drop in, save me some trouble and time in the long run, no to find a ggod one :)
Louis
adsm08
Ford Technician
3,614
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
That's probably going to be quite a bit easier in the long run.
bronco_lou
Columbia, SC
94 explorer 4.0
Well I got the 4.0 in tonight, just 2 bolts in the tranny and sitting on the mounts, will put some bolts on tomorrow and maybe ready to start this weekend. I can not wait to see what the differance will be.
Anyone have a few pics of an explorer under the hood in stock form? I might have to take a trip to the old JY and take a few.
Louis
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
