Zero_Cool
- Jul 25, 2013
- Reaction score
- 0
- Make / Model
- Ford
- Engine Size
- 4.0L
- Manual
I think my ecu on my 1992 Ranger is toast, I am getting a no start, and I have manually checked all my components to see if anything was toast, starter works, fuel pump works, all the relays work, fuses are fine the one thing that was not getting power is the plug for the clutch sensor (I have manual transmission M50D)
Essentially now when I put the key in the start position the lights on the dash come up, but fuel pump does not prime, and when I turn the key to start I get nothing.
Thoughts ???
Also are there any ECU's that are cross compatible with the Rangers, the code under the bar code is F17F-12A650-JA
Thoughts ???
