What can I do to make sure my engine is ready to go??
stus87BII
Hey I just bought an 87 Bronco II with a 2.9L. It runs pretty good with no funny sounds but due to the age I want it checked out maybe change the gaskets and thermostat. I will be driving it for winter and want to make sure its ready to go. I can do a lot myself but if I take it to a mechanic what do I ask them to do an inspection or Tune-up? And what would that cost me you think? It does look like the valves could be leaking a little. Any advice what you would do to make it ready for the winter? THanks!!
NEVERDONE86
Solid Axle Swap
3
Rio Rancho, NM
2.9l
Get everything for a tune up.... Plugs, wires, cap, rotor, and all new fluids couldn't hurt. A thermostat isn't expensive if u need one. It's not very hard to do. A Haynes manual will tell most everything you need to know. If u have any questions pm me.
NEVERDONE86
Solid Axle Swap
3
Rio Rancho, NM
2.9l
Valve cover gaskets are pretty easy on this engine also.
stus87BII
How much you think a full tune-up can run? Thanks for the feed back!
shane96ranger
221
Utah
Ford F150-Stang
Engine Type
V8
4.6 Triton / 5.0
That would be a question for your mechanic. You can probably do it yourself for under 50 dollars though. I personally would use Motorcraft plugs only - and who knows what your mechanic would use?
NEVERDONE86
Solid Axle Swap
3
Rio Rancho, NM
2.9l
Price will always be more with a mechanic because of labor rates. It shouldn't be to much money but a wise decision. Who knows how old some of the stuff has been in there. Might still be good but for how much longer. It's easier to change in the summer rather than winter.
Members online
Today's birthdays
Mudtruggy
May Truck of The Month
