veefer800canuck
- Sep 7, 2007
- Reaction score
- 7
- Location
- Alberta
- Make / Model
- Ranger FX4
- Engine Size
- 4.0
- Manual
Niiice.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I think you should. It really helps a lot. It keeps you motivated and moving forward every chance you get. Plus there are a lot of people here who can offer advice and solutions to problems as they arise. Often somebody will notice something in a photo that may not look completely correct. Then they will question it and get you thinking and suddenly you realize that it isn't right. Problem solved! Just by having another set of eyes looking at it.
Contact Chris.Just did, thanks for all that the info you have posted, also i want to do the brake set up you have, who do i need to contact and i actually have the means to machine my own parts so even templets would help.
Sent from outer space.
I wish I could. I don't have any plans or blueprints for the plate. My son gave it to me out of his V8 Ranger and I modified it slightly with the gussets. It is installed now so I am not able to take measurements at this time.Can you send me the measurements/blue prints for the transmission mount adapter? Thanks
I didn't think the one my son used on his earlier Ranger would fit the 99 I have. I was prepared to toss it and mock one up with cardboard and a Sharpie. I test fit his after it had been sitting in my tool box for a couple years and it fit perfect. Everything bolted right into place. I just ended up adding the sides and the back to build in some rigidity.OK no problems I'll figure one out haha thanks anyways
I have not got that far yet. I did take some early measurements just to get an idea and to get my mind working. It looks like the 99 Ranger drive shaft is to short, 3.0 V6, auto. The 98 Ranger looked pretty close, 2.5, 5 spd. (daily driver). I took the measurements before the trans was installed and before the final resting spot for the 306 was located. I will need to go back and get exact measurements before I will know for sure.Nice. Did you have to have a driveshaft built with the transmission pushed ahead with the plate?
Oh Boy!Great work, looking forward to updates. Speaking of updates, I've got one too. Gonna hijack for a post, I decided to downgrade my 5.0...
Yep, $hit just got real.
SVT
Yep, got it all figured out. I still need to tie them in but at least I know where each wire goes.So did you figure out your wiring for the two plugs? I'm there now, I've re-read this a few times to get the idea of it. Raining at the moment, looking forward to going under the hook and solving it. Besides that, waiting to get my keys programmed and I can try to fire it up!
