Upgrade 1988 Twin Fuel Pump to single HP Pump
lstill
Milton Florida
2.9
Hi Guys, jus bought a 1988 Bronco 2 4x4 with external HP fuel pump problems. Has anyone replaced the two pump system on the 1988 with a single HP in tank pump on the 1989 up bronco 2s. looks like the single system HP in tank pump would be less like to have the problems associated the the two system pump on the 1988. any input appreciated!:icon_idea:
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
If you get just the pump for an 89 it can be grafted onto the 88 sender, but you can't use the whole 89+ unit because the resistance ranges for the fuel level sender are different. Your fuel gauge would read wrong.
Personally, for as much fun as getting the tank in and out is on a BII I prefer the dual pump setup. The HP pump is more prone to failure, and is easier to access.
Die.Fledermaus
RBV's on Boost
4
State of Jefferson, USA
Engine Type
2.0 (4 Cylinder)
2.9
0"
Given a choice, I would all ways favor a two pump system.
SenorNoob
567
Middle Tennessee
Engine Type
4.0
2WD / 4WD
1.5" Front + 4" Rear
245-70-R16
The single pump is system is simpler, but without the reservoir in-line is limited to a shorter time at crazy angles (or sideways motion) before there is no fuel to the engine...
Basically, for donuts the 2 pumps are better! :)
Staff online
Shran
April Truck of The Month
