4dx2
- Aug 20, 2013
- Reaction score
- 0
- Make / Model
- Ford
- Manual
1990 Ranger 4x2 2.3l, 5speed. Let me start by saying i have used the search function, and narrowed it down but need a little more help, please. First Ranger, Like the truck, but it idles pretty low causing really rough take offs unless im revin it pretty high. Need to reset the idle, plus i like having a tach and knowing my power band.
First the green wire to tach signal. Tech library says 1990= black and yellow.
These wires are coming out of the bottom of fuse panel under hood. The bottom wire is mainly yellow with a black stripe, the second from bottom is black with a lime green stripe, and the top is a faded yellow with black stripe. Please help.
I did find a black and yellow wire coming out of the front of the fuse panel but it looks like it leads to the head lights.
The next is the white wire to 12 volt dimmer. Knob is to the right of the picture. Anyone.... Please
And last, the red wire to +12v fuse box. My fuse box doesnt match the tech library listing. Which fuse should I wire to, and which side of the fuse is the power out side.
Thanks for the help guys!!!
