Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Thanks @theBlake, right now, just ran into another problem. Truck cranks but won't start. Will check fuses tomorrow in day light. Battery is brand new. My zip is 78227, bummed right now.I have an extra left over from my donor vehicle if you'd like it... can send at the cost of shipping from 35040 zip code. Just lemme know [emoji6]
Sent from my 2PS64 using Tapatalk
No, you use a timing light (not quite the same as a strobe light) to check ignition timing. The timing belt has nothing to do with ignition timing. It keeps the crank and cam in time with each other.Quick question on the timing belt: could I just use any strobe light to check? I've got a headlamp with a strobe function, hoping I can just use that
No, no OD switch on a manual trans.Originally I had an Engine Light and MAF code.
Swapped out the MAF Sensor and cleared computer.
Ran alright for 3 days.
Checked:
Got spark
Can't find the little nozzle to check fuel.
Got Car to start, after pumping the gas peddle
After 3 days
Engine Light went back on. Autozone Code Check Results:
Soution is : Replace Overdrive Switch is there such a part on a standard transmission truck? Where is it located?
Definition
Code P0171 indicates that the Bank 1 System is too lean for a predetermined period of time.
Error Codes Read
P0171 Adaptive Fuel Trim Too Lean Bank 1
I don't know. Go get a tape measure.Question is which is the correct upstream length for 1999-2000 B2500 SE Manual Transmission 2DR Cab? Upstream Length 15.4 or 10.6 inches. Also which is better Bosch or Denso? My truck left me stranded in supper market lot
