Thinking about doing a 5.0 swap in my 86 4X4 ranger need advice
joeschmo2190
3.0
So i have a 1986 ford ranger 2.3 5 speed manual (fm145) 4x4 its a single cab long bed if that helps for my next couple of questions...
I have a nice rebuilt 5.0 block and at 1 point was thinking about doing the swap but was worried about having to have my driveshafts shortened/lengthened for the swap.
I been thinking theres got to be a way to do it on the cheap by either being able to reuse the existing drive shafts, or a driveshaft from a different car that could be found in a junkyard.
I want to keep it manual cause i love having a 5 speed even more so if i do a 5.0 swap. I had read that a M5OD from a 5.0 f150 would work for this setup. so that leaves me with figuring out a tranfercase and driveshafts on the cheap to complete the swap.
Can anyone give me some cheap solutions for driveshafts and a manual style transfercase that i could pick up at a junkyard?
Elutheros
129
Central Texas
Engine Type
V8
5.0
2WD / 4WD
Don't know if this will help, but here is the link to the ongoing saga of my build.
http://www.therangerstation.com/forums/showthread.php?t=150282
I wanted to do it as cheaply as I could and I'm quickly approaching $3000.00 and still have to get the front drive shaft shortened and an exhaust fabricated. I went with a HO block, rebuild, GT40P heads and Explorer intake, M5ODR2, and NP205 transfer case. The rear drive shaft swap cost me about $60 total. The front is going to be more. Just trying to help you see what can be done. The cost of the truck itself is included in that ($750), so you can do it pretty inexpensively. I've been at it since April, and I'm very close to first start-up--and I don't own a welder, so that's slowing me down.
Members online
Today's birthdays
Mudtruggy
May Truck of The Month
