Block Id
Ford78
December 2012 OTOTM
Iowa
351w
Was tearing the motor apart today and decided to look up the casting numbers and think I have a 351 instead of a 302.
Here a the casting numbers that were on the block- E3AE-6015-BA19 And above those we're- 3J6
From what I could find its a 1983 351W is this correct? Any help in decoding the numbers would be helpful.
Mac
183
C. Wisconsin
2000
199
3J6 indicate Sept 6, 1983 as the date cast.
Dave
Ford78
December 2012 OTOTM
Iowa
351w
Thanks, so am I correct that this a 351 block?
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
I think you can visually see the difference between a 302 and 351
Snake PLissken
The 351w intake is much wider than the 302, 5.0 engine intake by all most 2 1/2 in do to the taller deck height of the 351w. is a good way to spot the 351w you can also check the part number with a ford dealer parts or online if your still wondering what you have.
win
12
Correct, an easy way to tell a 302 from a 351 is by comparing the deck with the top timing cover/water pump/water passageway bolt holes.
On the 302 (and it's smaller displacement bothers), that top bolt is almost at deck level
On the 351, there's an additional 1" of block above the bolt holes to the deck.
don4331
1,354
Calgary, AB
5.3
Ford78:
E3AE-6015-BA19 =
E - 80s
3 - 3; so EA = 83
A - Full size
E - Engine
6015 - Engine block
BA19 - Change code
If you have tape measure, crank centerline to head is ~8-3/16" (8.200") on 302, while it is 9-1/2" on 351w.
Retraction :) That new picture clearly show ~1" spacing between the head and the water pump bolt. Its a 351w
Ford78
December 2012 OTOTM
Iowa
351w
Thanks guys for the help, I'm pretty sure it's 351 here's a pic of the distributor u can see the added deck height above it. A 302 should be almost flush.
Ford78
December 2012 OTOTM
Iowa
351w
Here's a pic of a 302 block I found on the web , u can see the manifold is almost flush with the distribitor.
