What's your exhaust setup?
Sharkin904
Figured it'd be cool to learn what everyone runs/will be running.
I've got stock Explorer manifolds still, No Cats, 2 Flowmaster Supper 44's, and running the front 2 02 sensors. Getting codes and a flashing CEL, so I'm thinking that isn't going to workout.
ascentpro
ASE Certified Tech
Provo, UT
You would need to get the rear O2's deleted in your computer to run like that without a CEL. I'm running the front cats from the explorer and all 4 O2's then merge into 3 inch pipe through a glass pack and dump by the rear axle.
win
12
Torque Monster headers
OEM '96 Expo front and rear cats
DIY Y pipe using the '96 Expo muffler and some 3" exhaust pipe
1990 GMC P3500 diesel muffler
Still need to add a tail pipe
Might only be a single exhaust but sounds great without waking the neighbors.
Jbrown1238
6
Largo, Fl
306
None
Torque Monster headers, front O2's, no cats, custom removable mid pipe with x pipe, two Flow Master Super 44's, dual out the back. All 2 1/2, maybe 2 3/4 (still trying to decide) mandrel bent stainless.
Scott B.
EMT / Paramedic
Georgia
'93
L&L headers, O2s, Magnaflow universal cats, Flowmaster Delta 50s (3" x 10" to fit), 2 1/2" pipe, H-pipe
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
SVT is running stock headers, front O2's, no cats, 2.5" from the manifolds that Y into a single 3" into a 2 chamber flowmaster and exit in front the rear tire into a 7" tip
ST is running stock cast manifolds rear O2's deleted into 2.5", Y into single 3" into 2 chamber flowmaster into 4" tip exiting in front the rear tire...
SVT
Fant
My truck is carb. One exhaust manifold is frm 77 f100. Other is 94 f150. Custom exhaust to two flowmasters. Pipe running straight back with chrome tips. Sounds aggressive when u really get on it but it aint to loud to hunt from.
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Advance Adapter headers on the 351w to true dual 2-1/2" straight pipes out the back. You could say it sounds aggressive.
