comp cam 49-422-8 in a 1991 4.0l
svtcards
137
Lyman maine
302
3'' front 4''back
I looking into putting a comp cam #49-422-8 500/500''hyd into my 1991 4.0l ranger.now my question is it says u need to replace stock pushrods with aftermarket ones but don't know what length ones I need?has anyone out there done this cam swap on the tm90 heads if so what length pushrods did u use.the rebuild section was to confusing for me to figure out.not an engine builder so trying to figure this out would probably wouldn't happen.if it did it probably wouldn't be right anyways.
chuckhotrod
Madza
Most common are 5.50 but honesty Id pick up a push rod length tool and make sure it isn't hard to do and you will know exactly and have piece of mind.
Peace. Not piece.
svtcards
137
Lyman maine
302
3'' front 4''back
cool thanx.im not to sure how to measure the length I really need though.never done it b4
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
years back i did the 410 swap and did order a set of longer push rods... place in Oregon search the site here and i am sure the answers will appear many did it before. you have an auto or manual trans? auto was in mine and went good with 410.
cheers
