10 mpgs???
92exploder4x4
I have a 92 explorer xlt 4x4 (recently aquired) and have been getting about 10 mpg's city/hwy. Now, I know these don't get fantastic mileage anyway, but I was at least expecting around 15-16 city/hwy.
Recently I have changed the fuel filter, plugs, wires, and air filter. I do have an exhuast leak at the passenger's side manifold. I tried pulling codes, but I have none. WTF is happening? Anybody got any ideas/tips?
ThatGuy
Solid Axle Swap
11
Oak Ridge, TN
4.0L
I dunno but that does suck. I get 17mpg in my 91 on 36s w/ 5.13 gears.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Were the plugs gapped correctly?
Does it seem to be running ok?
How is the trans fluid? Do you want to gag if you sniff it?
Do you have a K&N or similar air filter on it?
When was the last time the air filter was changed?
Have you cleaned the MAF lately?
Checked for vac leaks?
Front hubs locked in?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Yeah, what he said, plus the exhaust could be throwing the O2 sensor off
92exploder4x4
Plugs gapped right, cleaned the MAF when I did the plugs/wires/filters, no vac leaks, has a paper filter, and not sure if the hubs are locked in, how do I check?
Also, it runs great, drives great, I dunno...
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Well, if you have manual hubs, there is an arrow on the lock and "Free" and "locked" stamped on the outer rim.
If you have auto hubs, go backwards.
Check the MAF. It can go bad without throwing a code on those older ones. You will usually notice a rough running condition with that though.
How old is the O2?
92exploder4x4
I have the autohubs, shoulda specified. How long should I have to drive in reverse for the hubs to unlock? As far as I know, the o2's have never been replaced. I cleaned the MAF, with CRC MAF cleaner, and swapped the MAF from my parts truck to see if it made any difference.
The truck idles great, however at times it seems like it drives a little rough, almost like it wants to bog down on me when I give it some pedal, but it's really hard to tell because of the exhaust leak in the manifold (and in the muffler). The truck has 3.73's with stock tires.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
You should only have to go back about a foot to unlock them.
Bad O2 sensors could cause both your poor mileage and the bog-down issue. Country has a point too though. The exhaust leak at the manifold could be screwing with the O2 signal, making the exhaust show lean and telling to computer to give it more fuel.
I'd start there though. Fix your leak and throw a sensor on it. Those thing's don't last forever. They live in a very hostile environment and wear out after 100K or so.
92exploder4x4
Cool, I planned on fixing the manifold leak this Sunday, may as well throw a new o2 sensor in there as well. Thanks for the quick replies
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Well, we are here to help.
b2rich
Lake Oswego, OR
whats an engine?
Fixed my exhaust manifold leak, gave me about 4-5 mpg:icon_surprised:
92exploder4x4
Sweet, hopefully I can get close to that as well. Only one way to find out :D
92exploder4x4
Well, I put a new manifold gasket on, and it stopped the leak some, but I still hear exhaust leaking by somewhere in the front of the manifold, and I can't figure out where exactly. I also put a new muffler/tailpipe on, it is much quieter now, inside the truck at least. Still have to get an o2 and drop that in, hopefully soon.
92exploder4x4
Could bad motor mounts cause a decrease in mileage? I know mine are bad/going bad, m motor shakes like a mofo - even under acceleration.
b2rich
Lake Oswego, OR
whats an engine?
if your still hearing a leak, more than likely you need to have the exhaust manifold resurfaced.
Staff online
Members online
Shran
April Truck of The Month
