83-97 Manual Pitman Arm solution
cathalex
Thought I'd share with y'all how I got my manual box to fit my 94 2wd.
Plain and simple, the manual box is a copy of the GM Saginaw 525.
I did all my measuring and thinking and scheming and praying so I ordered a pitman arm from a 78-87 Metric GM (G Body: Monte Carlo, Regal, Cutlass) $45 bucks or so. Check Speedway, they sell all sorts of dirt track rot.
Dropped it on the box, and the angels sang. The power box nut and washer works on the manual box.
I did have to ream the drag link to fit the Ford taper, and I installed it all today. The steering shaft isn't exactly the same but it's driveable. Will be taking it back out to do the rag joint repair, but my shiznit has the manual box and works like a charm.
One caveat: The GM arm is a little longer, but what the hell, it's awesome for quickening the steering up. And it is a little lower, so the tierods/draglink is almost perfectly parallel.
Hope this helps, y'all!
BowlEEac
South Surrey, BC
302
do you have any pictures of this setup? it sounds like exactly what i need
gjeep9754
I was under the assumption that my jeep cj manual box was a saginaw 525 as well. I know that pitman arms of all sizes and drops are common for the jeep manual boxes. The arm on my jeep is a little long than the ford one as well.
chris1972
ASE Certified Tech
murray ky
what box did you use and any pics
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I recently put an 88 manual box with pitman arm on a 96 frame without any problems that I could see. There was a small but noticeable difference in the arm drop but everything went on and bolted tight. I was thinking I could correct the difference by bringing in the tie rods a half turn or something like that but haven't tested it yet.
Did you not have a pitman arm on the manual box?
