carrzkiss
- May 22, 2014
- Reaction score
- 0
- 85 ford ranger
- Make / Model
- Ford
- Manual
My 1995 4.0 EFI when I start driving it down the road, it seems to not want to take any gas. When I am pushing the gas pedal, it is as if no gas goes to the engine.
When it is idling, I can rev it up, and it does as it supposed to do. After about 10 minutes of idling, it will do the same thing and I am unable to rev it back up, I will have to turn off the ignition and then start it back up, and it will run fine for a minute or so, and then do it again, as if it is not getting any gas at all. This all happens, only when the truck is running after a while.
When I first take it out on the road, it will do fine in first gear, and then into second, however when I try to go into third, it acts as if it is getting no gas, no matter how many time that I press on the gas pedal. Then on the way home, I will have to drive a short distance, pull over on the side of the road, turn the ignition off, then start it back up, and drive a little further, and repeat the same thing, until I get home.
Things that I have done to this truck since November 2013. (It was broke down for over 2 years)
The following are new
Fuel Pump and assembly
Idle Air Control Valve
Spark Plugs
Oxygen sensor (Bank 1 sensor 1 Oxygen)
Fuel Filter
Area's that was cleaned with the appropriate cleaners.
MAF Sensor
Throttle Body
Used sea foam. And this made a HUGE difference in the way the truck was acting. However, it did not clear this issue, but others.
Anybody have any idea's on what could be causing the truck to loose its gas peddle during driving?
Thank you
Wayne
Spark Plugs
Fuel Filter
MAF Sensor
Throttle Body
Thank you
Wayne
