2000 ford ranger door repacement
pokie
stewartsville, mo
ford
3.0l
i would like to know how to swap a passenger side door, mine have power locks and window so do the electronics part of the swap plug and play or will i have to cut all the wires and reattach on the replacement door
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Well the question was hard to understand, but you don't have to cut any wires to remove the doors. There are plugs that can be unplugged to separate the wiring.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Born with a 3.0, looking for a donor V8
2WD / 4WD
2WD
Stock 2"
Stock
Doing things wrong, until I get it right.
If the replacement door is the same year it should just plug in. If the connections are different you should be able to cut & replace ones from the old door to the new door
pokie
stewartsville, mo
ford
3.0l
thanks for the quick replies, thats what i needed to know.
Staff online
Shran
April Truck of The Month
