1984 F/S Bronco donor???
BronKitis
TRS Banner 2012-2015
Spanaway, WA
2.9L
Guy has an 84' Bronco with a 351W and a C6 on CL for a sweet price, runs and drives. How will this combo fit in the BII?
1986fordranger
central VT
ford
2.3l/4.0l
running a 351, your gunna have width issue's, mainly exhaust manifold's to the frame rail's, you may need a body lift to fit the c6 depending on your transmission and engine mount height, 1984 will be carbed, so you'll need to remove some of the engine wiring harness under the hood or just tie them up out of the way
BronKitis
Spanaway, WA
2.9L
Thanks for the response! Yeah, I figured the exhaust would be bad but I haven't seen too many folks running the C-6....
I'm picking the whole rig up on saturday. Already has a Holley truck avenger installed :icon_thumby: What about ignition? Read in the tech article that the duraspark II system will plug into the original harness but not sure if this bronco has that set up or not... Gonna be interesting! :headbang:
Staff online
Shran
April Truck of The Month
