- Aug 6, 2007
- Reaction score
- 8
- Age
- 36
- Location
- Plattsburgh, NY
1999
- Make / Model
- Engine Size
- 4.0. 4.0 Supercharged
ive got a 76 axle i rebuilt to swap into my 95 ranger.. well i went ahead and ordered some wheels for it. got them yesterday and noticed an issue? wheels are 15x10 with a 4inch back spacing. the edge of the wheel is extremely close to the knuckle area next to the tierod . its not hitting tho. think it would be alright to run it like that? also iam doing the one ton tie rod y link set up. is the one ton tie rod physically bigger than the factory bronco tie rod? if so then i can see that being a problem with the wheels. i had 2 crappy 15x8s that were on the back of the truck when i got it and put one on for comparission and theirs quite a bit of room between the rim and the knuckle. figured id get your opinions on it. i went with the 10inch wheels because iam running 15x10s and 35s now. 2nd question. i ordered a y link steering kit. what the pro/con to running the linkage under the knuckle vs over the knuckle?
