chromoly ranger shafts, biggest tire size?
swynx
9
lewiston idaho
Mazda
So as some of you may know. I contacted a company about having a set of chromoly axle shafts made for the Dana 35.
I know lots of people run 35s I've seen quite a few on 37s and heard about 40s.
Seems like most run 35s reliably. Think they'll hold 37s reliably?
I'm talking full circle clips, 4.88 gears, an aussie, spicer u joints. The usual upgrades.
Chromoly 4340 is supposed to be about 30%? Stronger?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I would say 37s. Above that the ring & pinion I suspect may become an issue, though I can't say for sure (almost no one ever busts R&Ps, probably because running stock axle shafts that give out first).
I know people often do the Super-35 kits (30-spline conversions) on Jeep rear D35s and I'm not sure if I've seen a plethora of busted R&Ps there either (plenty of bent housings though lol), so maybe there's some hope for the HP front version since the front doesn't see the same workload as a rear axle.
For sure you're entering territory that hasn't been heavily charted yet.
swynx
9
lewiston idaho
Mazda
I figured as much that no one has ventured here. I'm doing this mod when money permits. Hopefully this summer. If so ill be sure to do a write up and let every one know what happens.
bigmark303
RI
4.0, 2.5
you pretty much have to look at it as you are still running a D35 in the end and with 35+ inch tires the chances of something breaking are more than likely.
The way ive always looked at it is do you want something easy to replace be your weak point or do you want something difficult being the weak point and when it does break you hope you can get the truck out of wherever you are so you can fix it.
I myself would rather keep the hubs as the weakest point and then from there the shafts/u joints. Pop the wheel off and throw a new hub on it right in the trails. Get the truck somewhere you can jack it up and with simple hand tools pull and replace a shaft right in the trails. You can carry spare shafts and hubs and get them in so you can make it out. Its not that easy doing a differential case swap in the woods so you can get out.
Even beefing up the shafts they are still made of metal and metal is malleable. The U joint ears will still be weak and probably give out before the shaft just as they do in stock form. The shafts are already pretty strong its the u joint ears that twist and distort.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Something that might help is to have the R&P gears cryogenically treated before you install them. I've seen some reports this adds something like a 10-15% strength increase.
swynx
9
lewiston idaho
Mazda
Hmm that is a good idea. The reason for the chromoly shafts is the ears. People seem to twist tthose off a lot. Idk that ill run 37s but I might. Ill run it on 35s first tho.I just really wanted to keep the ears intact. Seems like they wear out or something. Ill most likely keep the hubs as the weak point. I'm not a mash the gas kinda guy. But I also think the ring and pinion won't be a problem. I run in mud and snow that's it. When I get stuck its because im high centered. Guys run 40s on a Dana 30 around here. That tells you that we don't have the toughest of trails.
