I plan on swapping a v8 into a first Gen ranger or possible newer. I haven't decided yet, and would like some input from others who have done this. Itll basically be a daily driver. I'd prefer a manual trans but if necessary I'd settle for an automatic. Has anyone done this and was it worth it? I'd also like too keep the build as clean as possible.
I like the simplicity of a Carb. My biggest concern is my wallet in this build! I will definitely cut corners were it matters but I'd like this build too last! What's my best option for a long lasting daily driver?
So basically if i got a 98 through 00 ranger and explorer all the wiring is pretty much plug and play? I know most v8 swaps involve a 83-97 ranger. I really dont like the front ends on the 89-97 rangers.
Thank you SVT! That answers the engine part! Id like a manual transmission In the ranger if possible! And without having to cut another hole for a shifter what are my options? Ive read somewhere a tremec might fit?
Id like the longest life possibe out of this swap and a manual transmission Just seems right but id settle for and automatic if necessary!
so...you want a 2wd daily driver with w manual trans? most likey a gen one?
the ideal trans if you were to limit yourself to a small block ford would be the m5od r2 from a v6 97-04 or so ford 150. your floor board is easily adapted and modified regarless on the trans tunnel in a gen 1 or rangers in general...just need to make a bolt on plate to fit your needs to replace the original tunnel plate. the 97 up trans has smaller bolt holes so you need step studs or to drill the holes out a little....cake job.
in todays market, there are quite a few attractive options for powertrains.
the hemi, the ls, and the newer crop of v6 across the board make the idea of a blown out explorer 302 swap look patently ridiculous. then theres the supra stuff.
i have extensive experience and bias towards wheezer 302 swaps...and they are cheap and easy....and usually last quite well. whether installed by a shop at a cost of 5 to 10 times the typical wheezer crown vic/150 powertrain, or hacked in place by a drunk monkey.
now, what usually leads to a cost effective selection is.....remove from running donor....place into reciever. with the sla chassis ranger and v8 explorer it is as plug and play as it gets, real tempting to say the least. cost wise it usually is easy to free up enough cash to put a tfs system in place and actually have some power because of the low cost of clapped out explorers... dialing and maxing economy from there is a bit of work but nets respectable results.
as simple a formula as that is, its still not easy for many.
so, if you have to change every part of the drive train anyway, the other modern v8's are worth a look.
my first choice is the ls based on the power available from the typical 302 oem donor. but have yet to install one in an rbv.... i have put them in cars, jeeps, and race cars/trucks.
i have installed, mopar small blocks, 302 and 351 ford, 350 and ls gm into jeep cherokees and wranglers along with several big blocks. the first 6.0 ls i worked on was right when they came out and i had to figure it all out and that sucked...but the physical install was stupid easy. now the control systems are stupid easy and cheap as well. based on the comparatives from those applications its tough to take a oem 302 over a oem 5.3.
the other option is diesel. if your happy with a low 2wd the vw diesel may be a great option that will net some decent power and killer economy.
but it wont sound like a well constructed 302....hard to beat the sound of one of those.
look around locally and see whats out there for running complete donors and figure from there.
