HeadUnit
2.3LRNGR
West Seneca
4.0
So im gonna buy a brandnew pioneer head unit from my friend for a 100 bucks. I was wondering if there was a thread that had a how to for hooking it up I own a 99 ranger
06RangerXLT
54
Georgetown Ontario
4.0L
go to bestbuy, grab the install bracket and wire adapter kit. then attach the same color wires from the radio to the adapter, and plug her in.
cody93
42
Duluth GA
FORD
Engine Type
V8
5.0
2WD / 4WD
2WD
yea, what 06 said, get the adapter kit, so you dont cut into your factory harness, you'll thank us later. nothing sucks more to buy a used truck with a mis-functioning radio to find that the harness is missing....
2.3LRNGR
West Seneca
4.0
On a scale of 1 to 10 how hard is this install
fastpakr
Forum Staff Member
TRS Event Staff
2,849
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
If you've ever done a radio install before, it's not hard at all. There's nothing unusual about a radio install in an RBV, just a basic dash bracket and wiring adapter. Match colors on the wiring adapter to the new deck's harness and splice them together properly (no wiring nuts or purely electrical tape connections). Get access to the old radio and remove it. Plug the new radio in and mount it up. Enjoy.
FlyinRyan
Nova Scotia, Canada
Mazda
2.5L
The only issue I've run into is an OLD head unit. If it's very old then the standard 'match the wires' doesn't always work. If you're getting a manual with the stereo its never a bad idea to check, if not, google!
fastpakr
Forum Staff Member
TRS Event Staff
2,849
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Good point. Rarely an issue anymore, but worth verifying.
Heavyfire14
19
imperial valley
FORD
2.9L
the tech library here has some info on this.
2.3LRNGR
West Seneca
4.0
Its a new head unit my friend bought it a couple months ago
cody93
42
Duluth GA
FORD
Engine Type
V8
5.0
2WD / 4WD
2WD
+1 on not using wirenuts/electrical tape, my truck's radio was wired like that when i bought it, big F-ing mess, ripped it out, found wat was left of the old harness-4 wires and bought a stock boneyard radio, soldered on the jy harness to the remains and never looked back.... solder with heatshrink tubing or crimp on connectors and make sure no bare copper is exposed..
2.3LRNGR
West Seneca
4.0
No i never put in a headunit before but im kinda handy with shit like i can change oil and brakes
cody93
42
Duluth GA
FORD
Engine Type
V8
5.0
2WD / 4WD
2WD
its quite simple when you get all the parts you need, first is the mounting bracket, they come in various sizes for various trucks, get the one for yours and install it, your new stereo will slide right in, next is the factory to after market wiring harness, it plugs into the factory harness and will either plug directly into your new head unit or have wires you can splice onto the harness that was included with your new stereo. just grab pinouts for both harnesses and splice wires that match, ie SPKR LF+ to SPKR LF+, BATT+ to BATT+, ACCESORY+ to ACCESORY+, GND to GND, etc..
2.3LRNGR
West Seneca
4.0
What connectors should i use and wire strippers should be good enough?
cody93
42
Duluth GA
FORD
Engine Type
V8
5.0
2WD / 4WD
2WD
best= soldering and heat shrinking video
good= crimp on connectors video
shitty I dont G.A.F. job = twisting bare wire and electrical tape or wirenuts
soldering irons are cheap and you dont have to use flux or a heat gun to do a good job, most solders have the flux inside them, so just twist the wire together (remeber to put the heat shrink tube on before twisting) take the iron, heat up the wire while touching the solder to the wire. then slide the heat shrink over and take your iron and rub it till it shrinks,
next method is crimping, besure to strip the wires good and not cut off strands when you strip. give it a lil twist, slide the end in and crimp, the heat shrink ones work good if you have a heat gun, but a regular cigerette light works too if you careful.
good luck!
2.3LRNGR
West Seneca
4.0
There be enough room to use a soldering gun for the radio and where could i get one
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
