2ruble
- Jan 3, 2017
- Reaction score
- 0
- Location
- Loganville, GA
- Make / Model
- Ford
- Engine Size
- 2.9
- My credo
- "Don't trouble trouble until trouble troubles you"
I've been told by several to just use the OHV out of a ranger or explorer but my friend who would be assisting (at least solely with electrical, lol) says that the electrical isn't an issue, it's getting the motor in that's the concern.
I've seen some stuff on here about how the OHV essentially is an R&R motor for an 89 B2 whereas to make a SOHC fit there's much more electrical work needed. As well as, lifting the body, cutting the core support, notching the subframe... etc. Is that the case? I'm just trying to figure out the best spare vehicle to purchase instead of having to source everything individually. Does that make sense?
For instance, I can get a 95-97 4.0 explorer and still have the OHV motor as well as a D35 and the disc brake 8.8; or, I can get a 97+ explorer and get the SOHC with the D35 & disc 8.8. I would still need to source the manual trans for either of those. Or, I can source a 90-00 4.0 4x4 Ranger for the D35, OHV and manual trans but then still need to source an 8.8 rear.
Are all the OHVs the same if that's the route to go? Can I get any of them and it's the same "ease of transplant" due to size and wiring vs the "oversized/engine bay hacking" electrical monster that is the SOHC?
The B2 will essentially be a dirty weekend toy. So I'll still need some insight as to how far I would need to take all the axle upgrades and lift. I would like to get a 4.0 and refresh it at least to drop in, get the 8.8 disc rear and a d35 and freshen those up. I've been told I can use my transfer case for any of the 4.0 swaps but I should REALLY find a 4.0 manual trans as the 2.9 won't hold up long. I'm not looking for anything crazy to drive as it'll still be on the road and I'm not rock crawling. I figure a few inches (has two inches already) and maybe some 31-33s. I've been looking around to see what's needed driveline wise for that kind of mod as well as adjusting gears, but do I really need to do D44 knuckle swap, or any of the other long list of "bombproofing" listed on other pages?
I have no problem with over engineering and would love to have it more than strong enough for anything I intend to do to try to help ensure we don't break down on the property, lol
This rig is essentially (at least at first) going to be used for getting through hunting property, through some mud and more beginner/intermediate trails until I have more money and time, lol.
OR, should I just leave it how it is (2.9L 5spd with manual t case and manual hubs, looks like a 2" lift with blocks in the rear and a full spring up front) and just put bigger tires on it?
