Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 02-05-2011, 10:34 PM   #1
hartwrenches
Junior Member
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
hartwrenches is on a distinguished road
Default timing adjust
Is there a way to advance the spark timing on a 94 2.3 with DIS, I understand you can advance the cam but that doesn't really change the ignition timing at least not on mine, only has crank sensor
__________________
94 ranger 4x4 2.3l 225000+ miles on origanal motor with only a valve gob.
hartwrenches is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-05-2011, 11:33 PM   #2
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Vehicle Year: 89
Vehicle Make: Ford
Vehicle Model: Ranger S
I use this vehicle for: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
as far as i know you can only do it with a chip.
why do you want to advance the timing anyway?
BRUTUS_T_HOG is offline   Reply With Quote
Old 02-06-2011, 01:04 AM   #3
Duane867
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Daily driver. Fishing vehicle. Use from time to time to run down crack heads.
Duane867 is a jewel in the roughDuane867 is a jewel in the roughDuane867 is a jewel in the rough
Default
You have a cam sensor too.
No adjustments for the end user though. Its all computer controlled.
__________________
Quote:
Originally Posted by feellnfroggy View Post
Your drum brakes sh*t themselves and havent changed diapers yet.
Duane867 is offline   Reply With Quote
Old 02-06-2011, 08:14 PM   #4
DJ2.3
Junior Member
DJ2.3's Avatar
Vehicle Year: 83/92/94
Vehicle Make: Ranger
Vehicle Model: 2wd
I use this vehicle for: anger management
DJ2.3 is on a distinguished road
Default
A chip, tuner, or physically move your crank sensor. Your 94 shouldn't have a cam sensor, so you could slot the holes on the crank position sensor to adjust your timing. I have never tried it, but it should work even though it is somewhat a shot in the dark as far as how much you should move it. Another possibility would be an offset crank pulley key.
DJ2.3 is offline   Reply With Quote
Old 02-06-2011, 09:49 PM   #5
Duane867
Vehicle Year: 1993
Vehicle Make: Ford
Default
camshaft position sensor. 1994 Ranger 2.3L :
http://www.rockauto.com/catalog/raframecatalog.php
Its up top opposite side the coil packs.
__________________
Old 02-06-2011, 10:19 PM   #6
DJ2.3
Junior Member
DJ2.3's Avatar
Vehicle Model: 2wd
Default
The link didn't work for me. I think the 94's in California had them but most don't. I know for a fact that my 94 doesn't. Starting in 95 they all had cam position sensors.
Old 02-07-2011, 03:01 PM   #7
v8318cid
Vehicle Year: 2010
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Occasional DD
v8318cid is on a distinguished road
Default
The cam sensor is the key. While it is possible to alter the base timing by mechanically altering the location of the cam in relation to the crank, the computer will try to compensate, especially with a cam sensor. For those who say it isn't possible, I can attest that it is, at least on those without a cam sensor (92 for example). I don't recommend it since the engine will either ping or knock depending on whether you advance or retart the timing, but sometimes advancing the timing will boost MPGs (very marginally). Do so at your own risk though.
v8318cid is offline   Reply With Quote
Old 02-10-2011, 09:32 PM   #8
hartwrenches
Junior Member
Vehicle Year: 1994
Vehicle Make: ford
Default
The truck has 250000 plus miles on it and the engine is getting a little tired, on my older rangers I would just bump the timing a little and regain some power and fuel economy, just want to go 2 degrees or so with this one.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
