Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 05-19-2012, 07:01 AM   #1
hurgrave
Year: 1987
Make: Ford
Model: Bronco II
Engine: 2,9 (177 ci)
Class: 4x4
Used For: my own headache
hurgrave is on a distinguished road
Default Atypical starter problem. I'm out of ideas
Hello, camrades!
I have a non-common problem with my 1987 Bronco II XLT (manual trans). And I'm running out of ideas how to fix it.
My starter drive teeth seem to slip on flywheel ring gear teeth. The fork throws starter drive forward long enough (about half an inch). It just seems the diameter of starter drive or flywheel ring gear is not enough. The teeth engage by the very edge. Both the starter drive and flywheel ring gear were taken by using a Ford part number and it's (the last purchased) a 9-teeth OEM drive. The starter flange seats in place with no misfit, the bolts are torqued.
I had changed four starter drives and one flywheel ring gear. And even one rebuild starter. With the same result. One or two acceptable starts and then... the same goddamn grinding sound and chewed teeth on starter drive.
I'd be most happy if someone will tell me what to do.
hurgrave is offline   Reply With Quote
Old 05-19-2012, 01:23 PM   #2
Elutheros
Premium Member
Elutheros's Avatar
Year: 1987
Make: Ford
Model: Bronco II
Engine: 2.9 now 5.0 later
Class: 4X4
Used For: DD/Hunting
Elutheros is on a distinguished road
Default
Was the BII changed to a manual trans or is it the original? I ask this because I put the 4.0 clutch kit in mine and had to change the starter to the 4.0 manual version to match the larger flywheel.
Elutheros is offline   Reply With Quote
Old 05-19-2012, 02:19 PM   #3
TUX
Year: 1985
Make: Ford
Model: Bronco II
Engine: 2.8 V6
Class: 4x4
Used For: Everyday, Everywhere
TUX is on a distinguished road
Default
I have this issue too. I think it might have something to do with aftermarket starter, possibly the number of teeth/diameter of their bendix. I have only been able to jerry-rig mine to work for a few months (at most) at a time by shimming the starter a bit so that the bendix is kinked toward the flywheel.
Start by pushing the start as close to the flywheel as possible, there is some play in the position the starter will sit, that will get you close. Then I have used a piece of sheet metal (18ga?) folded over once and shimmed in just inside (engine side) of both starter bolts, right at the starter's bolt flange. This makes the starter sit crooked in it's place but gets the gears a bit closer together.
This is a crap "solution" I know, but it is better than push-starting your truck all the time. I also keep a short 3/8 drive ratchet (cheap-o HD husky works great) between the driver's door and seat because this is a constant issue :( Good luck.
__________________
If I wanted a computer on wheels I would build one
TUX is offline   Reply With Quote
Old 05-19-2012, 02:53 PM   #4
jrpdash9
Premium Member
jrpdash9's Avatar
Year: 2000
Make: Ford Ranger
Model: XLT ext
Engine: 3.0
Class: 4x4 Off road
Used For: just about everything
jrpdash9 is on a distinguished road
Default
sounds like a auto trans starter in the wrong application
__________________
2000 Ranger XLT ext, 3.0 auto, 4.10's limited slip, 31's , brush guard,custom skid plates, twin 12inch mtx subs in a mtx ported box with a 1600w amp::::: 1988 bronco II, rebuilt 2.9 with a rebuilt A4LD.manual t case.all orginal baby.
jrpdash9 is offline   Reply With Quote
Old 05-20-2012, 12:11 AM   #5
hurgrave
Year: 1987
Make: Ford
Model: Bronco II
Class: 4x4
Default
Thank you for the response!
Thank you for the idea. I haven't mentioned it. I had not swapped anything to 4.0 setup. Flywheeland clutch are new and bone stock. I used a CPD200 partnumbers for 2.9 before ordering. It's the only solution to get spare parts in Russia where I live. I have no experienced mechanics (in Ford truks), no instatntly available part stores. It's a 'push-and-see-what-happens' every time. So I depend on your advices much.
I do just the same. Thank you for sharing experience. But I got a bit annoyed turning bolts and nuts daily ;) I want to eliminate a problem once and for all.
Are those starters completely different? My ride came with a rebuild and the replacement rebuilt starter I've got from salvage was identical. My parts dealer told me nothing about different auto/man starters. Neither a Microcat CPD2000 catalog and Haynes manual. That's all I have of info about parts.
Is there a partnumber? Can you tell me?
Old 05-21-2012, 04:05 AM   #6
hurgrave
Year: 1987
Make: Ford
Model: Bronco II
Class: 4x4
Default
Can you, please, tell me is there a difference between B2/Ranger 1987 starters in auto or manual gearboxes? Manufacturers tell nothing but what if they're different?
Old 05-21-2012, 05:44 AM   #7
country0001
gravel in my travel
country0001's Avatar
Year: 1990,92
Make: Ford,Ford
Model: B2,F150
Engine: 4.0,5.0
Class: 4x4, 4x4
Used For: tearin up the gravel roads
country0001 has a spectacular aura aboutcountry0001 has a spectacular aura about
Default
There is a little more cut out on the manual starter. There is a different part number. Try WWW.autozone.com. It will give you part numbers
__________________
Quote:
Originally Posted by MountainMike View Post
"Quietly the BroncII waits for the prey to walk past, the Ranger will have to wait its turn."
BUILD THREAD http://www.therangerstation.com/foru....php?p=767381#
country0001 is offline   Reply With Quote
Old 05-22-2012, 11:57 AM   #8
Brownie Mobile
Brownie Mobile's Avatar
Year: 1984
Make: Ford
Model: Bronco II
Engine: 2.8l
Class: 4x4
Used For: To take up space in my driveway
Brownie Mobile is on a distinguished road
Default
Park on a hill sounds more reasonable to me i like rolling and starting anyways cause youre already going lol.
Brownie Mobile is offline   Reply With Quote
Old 05-22-2012, 02:31 PM   #9
Pbheadshots
Pbheadshots's Avatar
Year: 1984/8 mix
Make: Ford
Model: Bronco 2
Engine: 2.9
Class: 4x4
Used For: mud/trails
Pbheadshots is on a distinguished road
Default
In soviet Russia you don't start your car, it starts you... (just had too)
But seriously Are Mazdas common in RU? I know when I was in Guatemala Mazda mechanics where the only people who could closely work on ford trucks since they are rbv's.
Try looking at the salvage for a Manuel starter. To fix the problem all together you could always upgrade to the 4.0 clutch/flywheel/starter for the manual tranny. But $$ and part availability is your limiter.
Idk about RU but in guatemala part stores DON'T exist, unless you drive a yota.
__________________
I got 99 problems and my Bronco 2 is everyone of them.
Pbheadshots is offline   Reply With Quote
Old 05-22-2012, 02:32 PM   #10
hurgrave
Year: 1987
Make: Ford
Model: Bronco II
Class: 4x4
Default
My buddies have suggested I should install a kickstart
It's a pity but our local Mazda mechanics have not ever seen any Bronco. Beleieve it or not when I mentioned 'Crown Victoria' they seek for it in Toyota catalog...
- I have a Crown Victoria. I want to scan OBD codes. Will you...
- We are Ford/Mazda service center. We don't deal with Toyota!
- It's FORD Crown Victoria!
- Oh! But we don't deal with Pontiac too!
- It's F-O-R-D! USA Ford!
- We don't have appropriate scanner.
(Then I'm lucky to have a paper clip and CEL diag manual)
Old 05-22-2012, 09:47 PM   #11
Pbheadshots
Year: 1984/8 mix
Make: Ford
Model: Bronco 2
Engine: 2.9
Class: 4x4
Default
Trust me I know exactly how you feel. Us Americans are spoiled on how auto service is concerned, ever try and look for an obsolete part for a dodge truck in south america? Haha doesn't exist! It's like finding a needle In a cornmaze...
Makes you appreciate Things more.
__________________
Old 05-27-2012, 04:41 AM   #12
josh_cloud
Year: 1987
Make: Ford
Model: Bronco II
Engine: 2.9
Used For: elevating my stress level
josh_cloud is on a distinguished road
Default
im having the same issue with a bronco2 i bought a month ago. it had this issue when i bought it, so the first thing i did was replace the starter, flywheel and clutch. 50 to 100 starts later, the starter wont touch the flywheel. i double checked the starter when i got it to make sure that it was a manual trans starter. i'll be swapping out the starter tomorrow, but im sure it'll happen again. any ideas?
josh_cloud is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
