Amp draw
Cody Ray
Phoenix
What is the amp draw for low/high beam on a 2001 xlt ranger? Both my low and high beams seem to be quite dim and before I go hooking up my multi meter wanna know if it is above 10amps. The bulbs are brand new.
martin
26
St Bruno, Quebec
1991
I=P/V. The wattage is written on the bulbs, you can measure your voltage with your multimeter.
4x4junkie
585
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
#9007 DOT headlight bulbs IIRC have a 55W low beam, and a 65W high beam. ×2, that's right about 11 amps for your hi beams (it'll be higher still with the engine running).
Cody Ray
Phoenix
That occurred to me while I was typing, but I wanted a base amperage to compare my readings to.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Generally the problem is a dirty/corroded connection *Somewhere* (your guess is as good as mine) that reduces voltage at the bulb.
Do remember that the resistance can also be on the ground side.
If the bulbs are silvery/black looking simply replace them, even halogen bulbs only have a RATED service life of something like 1500hours.
AD
XLTsplash
June Truck of The Month
