Difference between Shortbox & Extended cab box.
koda6966
61
The green part of NY.
How much of a size difference is there between a short box ranger and a extended cab ranger's bed size? (93-97)
lil red
Firefighter
Dirty Jersey
the size of the cab.....
Monty35
Vancouver BC
the bed size is identical between a regularcab shortbox and an extended cab box
koda6966
61
So if I were to buy a bed, it would have to be either a shortbox from a regular cab, or a extended cabs box to fit? (this would also apply to tonneau covers)
I always though that the beds were the same size between regular cab and extended cabs with shortbox being well.. shorter..
Monty35
Vancouver BC
nope same thing. Only the regular cab longboxes were a different length. Though all 3 models have different frames
kunar
131
Toledo, Ohio
5.8l
a regular cab short bed and an extended cab's bed are both 6 foot. a long bed is 7 foot.
kunar
131
Toledo, Ohio
5.8l
krugford
Iowa
There are three combinations you get here (Extended Cab, Regular Cab, Short box, Long Box)
Regular Cab Short Box (6 foot box)
Regular Cab Long Box (7 foot box)
Extended Cab Short Box (6 foot box)
Both the Regular Cab Short Box and Extended Cab trucks use the same bed. There is no Extended Cab Long Box.
It's rare, around here anyways, to see a long box Ranger and they've always been Gen I or Gen II. I don't ever recall seeing a Gen 3+ long box Ranger that I remember, although it was an option I'm sure.
The 6 foot box IS the shortbox. It's a reference more for a full size truck where a long box (8 foot) is a lot more common. As I stated above, I see long box (7 foot) Rangers so rarely that if you tell me you need a box for a Ranger, I'll assume you're talking about a short box (6 foot) unless otherwise explicitly stated.
Does that clear everything up?
koda6966
61
Why is it called a short box then? Shouldn't it just be the erm.. normal option?
85_Ranger4x4
18,133
SW Iowa
Once apoun a time, the longer bed was "normal", the same goes for the "standard" cab.
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
because a short box is shorter than a long box, thats why its called a short box.
LearjetMinako
12
Moore, OK
2.3L 140ci
Its the same reason why they call a short bus, a "short bus". Its smaller than the rest.
Any gen3+ box should work. There is no difference unless you got the standard cab (no room behind seat) with the 7ft long box (longer than the 6ft short box).
Insanejughead
33
Missouri
'94, '86
2.3T
DakotahQ and I have longbed Gen 3's
Oh, and so does Salating.
There's quite a few gen 3's and up that have longbeds... you just normally don't "notice" them.
85_Ranger4x4
18,133
SW Iowa
They quit making them sometime in the mid to late 90's. I watch for them, and don't see that many.
Although I think I heard they recently brought the longbed back, still haven't seen one though.
XLTsplash
June Truck of The Month
