View Single Post
Old 08-29-2009, 09:13 PM   #6
Anger Ranger
Anger Ranger's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Topless Hearse
Anger Ranger is on a distinguished road
Default
I had a problem like that with the Ignition coils once I had a VW. When it rained, the car hesitated, and smelled like gas. Check engine lights, rough idling and low rpms. Everything was like that until.......it warmed up.......I tried many things but then I thought they were the ignition coils because in other forums people had the same exact problems. You might get a new ignition coil or the "epoxy" solution, or warm up your truck earlier when it had rained overnight.
In other words, moist gets inside the coils and cause a misfire and then a "check engine light". When your car warms up, the heat evaporated the moist trapped inside.
For reference google this: "epoxy solution ignition coils jetta", you will be surprised that a lot of people had this problem.
Hope it helped you a bit.
Anger Ranger is offline   Reply With Quote
